Subsonic 5.1 released
Re: Subsonic 5.1 released
Postby djedail » Fri Jan 23, 2015 11:05 am
IwishIcanFLighT wrote:Hi Sindre !
Thanks for this amazing update. Loving the new UI setup. :wink:
Sadly, the Home > Random page doesn't work since I updated (from 5.0 stable). It only shows my Media folder's name and the More button .
Capture:
http://i.imgur.com/oABz7zO.png
All other tabs (Recently added | Starred | Top rated | Most played | Recently played | By decade | By genre | All) works fine tho.
Any thoughts?
I had the same problem after upgrade. You have to re-scan the media folders to update the library... :wink:
djedail
Postby IwishIcanFLighT » Fri Jan 23, 2015 11:17 am
djedail wrote:I had the same problem after upgrade. You have to re-scan the media folders to update the library... :wink:
Thanks a lot for the lightning reply, it works fine now ! :D
IwishIcanFLighT
Postby brn2337 » Sat Jan 24, 2015 7:05 am
Overall great product.
Is there no way to change movie cover art anymore?
brn2337
Postby samy4972 » Sat Jan 24, 2015 10:24 am
Hello !
thks !
how to have french artist bio ?
how to disable ?
samy4972
Postby Exrace » Sat Jan 24, 2015 1:31 pm
Cleanup upgrade on server 2012.
Like the refreshed interface...looking better for how I use subsonic.
Thanks Sindre!
Exrace
Postby z-vap » Sat Jan 24, 2015 9:57 pm
Hi. So what's the best way to pre-download songs? I can't seem to find out how?
z-vap
Postby kargath » Tue Jan 27, 2015 12:19 am
Sindre,
I'm still having the incorrect sorting issue that's been in here for many revisions. I know during the 5.0 release, you PM'd me saying you were working on it for a future release. If that code made it here for 5.1, I wanted to let you know that something is still borked. It sorts directories into two alphabetical groups. One that contains exclusively directories, and another set that contains both loose files and directories.
kargath
Postby markusschloesser » Tue Jan 27, 2015 6:17 pm
i have the sorting problems as well, in my "new music" folder it goes through the alphabet 7 times. Pattern is imho age of folders
markusschloesser
Postby sindre_mehus » Tue Jan 27, 2015 7:06 pm
Could you please post a screenshot showing the sorting problem?
Thanks! Sindre
Postby noxon » Wed Jan 28, 2015 9:31 am
The cover art when looking at an album takes up so much space in the latest few versions. On my laptop, at the screensize i usually use my browser, i can't see song titles anymore.
Would it be possible to dynamically change coverart size when the cover art takes up more space than say, 1/4 of the frame it's in?
(kinda like this: http://webdesignerwall.com/demo/adaptiv ... final.html)
Or make some design things parameterized in the settings? Like font size, cover art max size etc...
noxon
Postby bjack003 » Wed Jan 28, 2015 5:27 pm
First I would like to say that I like the new updates that came along with 5.1, and the new Sonos additions as well. I do have something that I would like to see implemented. On the artist look up, not all of the artist look ups work from their folder view due to none of my folders containing spaces. For example I have "Linkin_Park" , instead of "Linkin Park". When I browse their album, it is able to pick up similar artists though. Is there a way that you could make underscores are replaced with spaces when you send the data to Last.FM?
Also, is it possible to make the Last.FM bio come in as secured. I run my site over SSL and the data from Last.FM isn't.
bjack003
Postby hyatari » Wed Jan 28, 2015 10:52 pm
Can someone give me a flac to ogg transcoding that will work with the latest version of Subsonic? past several releases I've been having to reinstall older transcoders to get it to work again. Here is what im currently using.
ffmpeg -v 0 -i %s -f ogg -vn -acodec libvorbis -ar 44100 -aq 4 -ac 2 -map_meta_data 0:0 -
This is mainly for use in Dsub on android. It just starts a track and never actually downloads anything.
Thanks.
hyatari
Postby rubbersoul » Thu Jan 29, 2015 4:06 pm
bjack003 wrote:First I would like to say that I like the new updates that came along with 5.1, and the new Sonos additions as well. I do have something that I would like to see implemented. On the artist look up, not all of the artist look ups work from their folder view due to none of my folders containing spaces. For example I have "Linkin_Park" , instead of "Linkin Park". When I browse their album, it is able to pick up similar artists though. Is there a way that you could make underscores are replaced with spaces when you send the data to Last.FM?
Underscores should not be interpreted as spaces, in general, because underscores are often used by default to replace any character disallowed by file naming convention. This means "Albert Hammond Jr." becomes "Albert Hammond Jr_" and "Akron/Family" becomes "Akron_Family"
The proper way to handle this is to look at the file's metadata which isn't subject to the same character limitations that folder names have. It seems like subsonic does look at these tags so I don't understand why it uses tags sometimes in some places and doesn't other times. I would really like to see improvement in this area as well, but hacks like replacing characters isn't the right way to handle it.
rubbersoul
Postby censu » Thu Jan 29, 2015 9:09 pm
hyatari wrote:Can someone give me a flac to ogg transcoding that will work with the latest version of Subsonic? past several releases I've been having to reinstall older transcoders to get it to work again. Here is what im currently using.
Thanks.
I successfully use the below 2 step transcode for Subsonic to Dsub:
Step 1
flac --decode --stdout %s
Step 2
ffmpeg -i - -acodec libvorbis -ab %bk -f ogg -
censu
Postby hyatari » Sun Feb 01, 2015 8:02 pm
Thanks.
Step 1
Step 2
Cool. Thanks.
hyatari
Return to Announcements
