Sonos owners wanted for beta testing
Postby sindre_mehus » Sun Jan 25, 2015 8:13 pm
For the last few weeks I have implemented Sonos integration in Subsonic. This means that your Subsonic server can act as a music service in Sonos, on par with Spotify, Google Play etc.
I have a Sonos Play:1 and Connect myself and it works like a charm :) However, I would like to do a beta test with a smaller group of users before making it generally available on subsonic.org
So if you're interested in participating, please reply to this post. Please include what Sonos equipment you have and on which OS you're running Subsonic.
(Note: The Subsonic server is required to be on the same local network as the Sonos controllers)
Thanks in advance!
Re: Sonos owners wanted for beta testing
Postby pdcorcoran » Mon Jan 26, 2015 3:04 am
Sindre:
I am definitely interested in taking part. I am running Subsonic on WHS2011 and have a Sonos bridge, two Connect amps, and a Play:3
pdcorcoran
Postby bjack003 » Mon Jan 26, 2015 3:21 pm
I would be interested in testing for Sonos. I have the Sonos bridge, and 2 Play:5. I have Subsonic running on Ubuntu 14.04 using Tomcat 7.
bjack003
Postby kargath » Mon Jan 26, 2015 11:23 pm
Is this mainly for people that would use it outside of their home network? If not, what are advantages vs just pointing it at the local directories like usual? It's neat either way..Just curious
kargath
Postby aylesburytim » Tue Jan 27, 2015 5:24 am
I'd like to help.. I have 2x sonos 1's and would love to have sonos integration in Subsonic.
Tim.
aylesburytim
Postby MrJernberg » Tue Jan 27, 2015 7:45 am
I'm using Sonos and Subsonic @ my office and can be used as a guinea pig if needed.
MrJernberg
Postby sindre_mehus » Tue Jan 27, 2015 3:19 pm
Thanks for volunteering! Please find installers here:
https://sourceforge.net/projects/subson ... onos-beta/
To get started, open Settings > Sonos.
Postby roastingrambler » Tue Jan 27, 2015 3:26 pm
I would help out with some testing. I currently use the .war installation using Tomcat7 and Ubuntu 14.04 and have a PLAYBAR, a few Play:1s, and a Play:3.
roastingrambler
Postby sindre_mehus » Tue Jan 27, 2015 3:27 pm
kargath wrote:Is this mainly for people that would use it outside of their home network? If not, what are advantages vs just pointing it at the local directories like usual? It's neat either way..Just curious
I guess the main advantages are:
o You don't need to install and run the Sonos controller app.
o You get access to your personal Subsonic playlists.
o You can star/unstar your favorites
o You get the exact same folder structure / album art / media meta data as in the Subsonic web app
o You get the same album lists as in Subsonic
o The Subsonic web app will show who is playing what on Sonos in "Now playing"
o Audioscrobbling and play statistics works
Postby sindre_mehus » Tue Jan 27, 2015 3:35 pm
roastingrambler wrote:I would help out with some testing. I currently use the .war installation using Tomcat7 and Ubuntu 14.04 and have a PLAYBAR, a few Play:1s, and a Play:3.
Great! I've uploaded the .war version now.
Postby baardog » Tue Jan 27, 2015 10:14 pm
I just installed the windows version, and so far everything is running great. Got some strange search results when searching for a-ha?
https://www.dropbox.com/s/7mc76egabx40pka/Screenshot%202015-01-27%2023.07.28.png?dl=0
And last.fm submissions does not seem to work.
Can I play directly to my Sonos system from within SubSonic, if I can how do i choose which Sonos to play to?
baardog
Subsonic v6.1.6 (build 0cfa60) - Windows
baardog
Postby roastingrambler » Wed Jan 28, 2015 1:58 am
Just got home and deployed the new .war. The Sonos service showed up immediately under the Add Music Services. I chose Add account and then "I already have an account" and tried logging in with my usual credentials and it didn't work. I got an Account Not Found message.
Then I realized even though the server is on my home network I was accessing it through my external hostname. After I logged in using the direct IP and clicked save again, it suddenly started working. I'm assuming that something in the code is reading the current URL rather than grabbing the local IP address? Just something to maybe add to the instructions.
roastingrambler
Postby bjack003 » Wed Jan 28, 2015 5:31 pm
This new Sonos feature is working great. I still have some more testing to do, but so far so good. This is working much better than the other app I was using to bypass the Sonos library size limit.
Keep up the good work Sindre!
bjack003
Postby sindre_mehus » Thu Jan 29, 2015 7:58 pm
roastingrambler wrote:Just got home and deployed the new .war. The Sonos service showed up immediately under the Add Music Services. I chose Add account and then "I already have an account" and tried logging in with my usual credentials and it didn't work. I got an Account Not Found message.
Do you still have the subsonic.log from when this happened? If so, could you please send it to me?
Postby mockingbrd » Fri Jan 30, 2015 6:48 pm
YES! Thank you so much for this, Sindre! I've been praying for direct Subsonic to Sonos compatibility for years! I'll be testing it out this weekend.
Subsonic on Win7 64
1x Bridge
1x Play:Bar
1x Play:5
2x Play:1
mockingbrd
Return to Announcements
