donpearson wrote:Video dont seem to work?
I there anything i need to do to get it all working or will it just play out the box?
sindre_mehus wrote:Let me try to explain what changes was done with respect to ports.
I removed the option to differentiate between internal and public ports in UPnP port forwarding, as this was confusing for many non-techy users. So if you're using UPnP and/or a xxx.subsonic.org address, the internal and public ports must be the same.
Secondly, the default port on a Windows install is 80. On Linux, Mac, war and stand-alone install, the default port is 4040.
The .deb and .rpm installers will remember port overrides when upgrading, but all other installers will reset to default port.
Hope this was clarifying.
taterb wrote:confirming chat is broken in beta. FF on both Ubuntu and Vista.
chat posts never appear.
tate
seanpkeown wrote:Hi guys,
I was wondering if anyone else was having this problem. I've been testing the new 4.0beta1 and have noticed that when i play wma files i get nothing but static. I couldn't figure out what was causing this so i blew my database away to see the the problem continued which it didn't. Until i set a max bitrate under the players and or the users tab then i start getting static again when playing wma files. A majority of my music is mp3 so it took a while for me to notice.
I also noticed that my android app started hanging after going to the 4.0. I'll post again once i figure out if it's a certain file type that this is happening on.
sindre_mehus wrote:Thanks SpritHansi for creating a test account.
The chat doesn't show up in my browser either, but it works agains my server, so it's most likely a server-side or network-related problem.
Can you please do one thing: Write some chat messages while looking at c:/program files/subsonic/log/subsonic-service.log. Look for any errors or warnings.
292209 [btpool0-8] INFO org.directwebremoting.impl.DefaultRemoter - Exec: chatService.addMessage()
294726 [btpool0-8] INFO org.directwebremoting.impl.DefaultRemoter - Exec: chatService.addMessage()
695371057 [btpool10-2860] INFO org.directwebremoting.impl.DefaultRemoter - Exec: chatService.addmessage()
