Subsonic 4.6 released
Postby sindre_mehus » Tue Dec 06, 2011 7:27 pm
Hi there,
Subsonic 4.6 was released today, 6 December 2011. A new version of the Android app will follow shortly.
Merry Christmas!
Re: Subsonic 4.6 released
Postby BKKKPewsey » Tue Dec 06, 2011 9:26 pm
Thank you - all installed and running
Postby gwadafix » Tue Dec 06, 2011 10:00 pm
download in progress .....thank you sindre :mrgreen:
working like a charme.... my jukeboxe problem seem to be solved with this release ..... i dont lost sound again on my pc when i switch on-off remote control
Than you sindre
gwadafix
Postby inslee » Tue Dec 06, 2011 10:23 pm
I tried playing a video to see if I could reproduce the video transcoding issues I was having before but it seems to be OK now (I tested it on my local network not over the internet though)
Also, I manually upgraded JWplayer by replacing the version in the subsonic installation folder with with 5.8 since it was still using 5.6
Thanks sindre!
inslee
Postby wesssider » Tue Dec 06, 2011 10:33 pm
Installed app, will update server when I get home. Thank you very much.
wesssider
Postby kleverbear » Tue Dec 06, 2011 11:31 pm
Perfect!
Ubuntu 10.04 LTS
Atom @ 1.60GHz, 4 cores 2Gb ram
6 Users
SubSonic 4.6 (build 2585)
2,575 artist
2,053 albums
16,090 songs
288.69GB (~4,484 hours)
kleverbear
Postby baxtr » Tue Dec 06, 2011 11:58 pm
Installed and running, Thank you!
baxtr
Postby pparth » Wed Dec 07, 2011 1:34 am
Hey,
I just updated as well but ran to a minor problem.
At the end of running the installer the Subsonic service under Windows 7 did not start. I looked under 'Services' and it was marked as 'disabled'. When I attempted to enable it, it gave an error saying "Service marked for deletion."
I rebooted the computer and the service was removed. I then re-ran the installation file and everything went back to normal.
Just a glitch it seems, but worth noting I thought.
PParth
pparth
Postby GJ51 » Wed Dec 07, 2011 5:49 am
OK - Maybe it's me ... Why do wtv files work in 4.6 beta2 but don't work in the 4.6 release? It appears that wtv files are no longer recognized as video files.
I too had to reboot to get the Subsonic service to run on my Win 2008 R2 server.
EDIT: Go figure, added the wtv extension and the transcode back and they are now working. Delayed reaction I guess. I originally added the wtv extension to the video transcode line, but then added it's own definition. My mp4 videos didn't transcode, so I just took the mp4 extension out so they would play direct to JW Player.
Went back and removed seperate line and readded wtv to the flv/h264 video line and now it works.
Postby Jesus Army » Wed Dec 07, 2011 8:50 am
Thanks Sindre, great release !
I have just updated it on my server running Win7, and I did not had to reboot it like previous guys. But I have stopped Subsonic service before starting the installation, so that's probably why...
Nevertheless, I love new Jukebox implementation has it seems to have fixed all playback problems that I had with some musics ! I have just noticed a short glitch sound from time to time at the beginning of each songs in jukebox mode, but hopefully you will find something for this in next release, and it's not so bad... :)
Great work and thanks again !
Jesus Army
Postby utopian » Wed Dec 07, 2011 11:21 am
just installed.. no problems
MAny Thanks for a great piece of software. :)
utopian
Postby germain35 » Thu Dec 08, 2011 7:39 am
thinks for the job sindre!!
i'v just installed subsonic 4.6 and i have a problem with iSub since the installation.
when i play a song, the song can stop 20 seconds before the end and go to the next song. this time is variable, it can 5s 10s 20s or much.... so its a bit annoying...
i haven't the problem with 4.5 .... i see in the change log you have made a fix about content length... perhaps it's linked to this update?
thinks for your help
germain35
Postby pdcorcoran » Thu Dec 08, 2011 3:39 pm
Also having a problem with iPhone apps and 4.6 final. Neither iSub or Z-Subsonic would connect, but I was able to access the server through Firefox.
After reinstalling 4.6 Beta 2, access to iSub and Z-Subsonic were restored.
pdcorcoran
Postby whimpyjones » Thu Dec 08, 2011 9:33 pm
Running 4.6 final and isub 3.0.4. Not experiencing any issues at all with isub
whimpyjones
Subsonic 4.6 standalone no media folders found
Postby michaelsonline » Fri Dec 09, 2011 12:49 am
Have issue with no media folders found.
I have input the correct folder info into the media folder section
it shows the field filled in and saves it
but still produces the error no media folders found as well as not populating the left side menu with the music.
I have also input the Playlist folder info and subsonic is able to see the playlists no problem.
Subsonic standalone is unable to see the media folder at all.
all files have the same user permissions as when I ran 4.4
When loading a playlist..in subsonic about, it lists this error "WARN PlaylistService Access denied to file /mnt/.......etc etc etc"
Thank you.
michaelsonline
Return to Announcements
