Byronnnn wrote:First impressions, its definitely fast. On 3g and Wifi, it cues up quickly. A few key things I like in other apps
- Ability to cache songs individually (swipe option or tap/hold)
- "Downloads" section of cached items to have the same Artist/Album structure
- Ability to set the bitrate
- Creating playlists
One other thing I noticed is it appears (I say appears because I may be wrong) to load the list of artists from the server again every time it launches. Maybe implement a pulldown to refresh and keep the list cache from first launch/last refresh (could speed up the already fast launching)
But good work, seems like a promising app. I will try to use it as much as I can and give you feedback.
ecleese wrote:I keep getting an API connection error due to a SSL problem. I'm assuming it's due to the cert being self-signed. Are you able to add an option to override self signed errors?
poiter wrote:Sonic stream will encode m4a (Apple lossless) well, but when trying to stream Apple lossless music over LAN I have the same error as the post above. I have tried with versions 4.5/4.6 on linux mint 13.
Will there be an upgrade to Sonic stream to allow this?
lacy1974 wrote:heddhunter
I replaced by freenas.7.x server with Subsonic(4.6) installed on it to Nas4free 9.x with Subsonic(4.6).
Nas4free is the freenas .7 upgrade track that allows Subsonic installation.
I am getting an API error message when I try to brows the folders.
I can use Z-Subsonic and ISub without any problems.
I like the Downloads folder in Sonic Stream.
