scanning but not picking up new files
Postby mbu10 » Tue Feb 26, 2013 1:00 pm
Got my install and been working fine for a month or so (over 110K of files) .
But just noticed files i have added in the last week have not been added.
Have cleaned the database and tried scanning mulitple time.
But so far not managed to update and list these files
they are in the correct path and the correct location
and in the correct format
any ideas?
thanks
mbu10
Re: scanning but not picking up new files
Postby mbu10 » Tue Feb 26, 2013 1:59 pm
well removed the subsonic folder and set it all back up again.
pain but picked up the files and re scanning now
anyway i coudl fix this ?? so does nto happen in the future
thanks
mbu10
Postby bushman4 » Tue Feb 26, 2013 2:34 pm
Nope. Not really enough information in the original post, and now the "evidence" is gone, so no way to analyze it...
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby hakko » Tue Feb 26, 2013 3:42 pm
This has been reported numerous times though, so I'd think it's fair to call it a bug in the default Subsonic media scanner. No-one has pinpointed it or presented a stable work-around afaik.
MusicCabinet developer
hakko
Postby GJ51 » Tue Feb 26, 2013 4:11 pm
I've posted the workaround several times.
Uncheck the media files, save, clean the database, rescan, recheck the media folders and rescan. I just had to do this yesterday. I don't know what the underlying flaw is within Subsonic, but I find this happens whenever I make certain changes to the files.
What happened:
I had two folders, the first was Mumford & Sons, then a second was created as Mumford and Sons. When we discovered that we had albums in each folder we moved the album that was in Mumford and Sons to the Mumford & Sons folder and then deleted the Mumford and Sons folder. Once done, a rescan would not pick up the album that was moved to Mumford & Sons.
I think that for some reason the db doesn't delete the entry for the moved album and then pick it up at its new location. I tried doing just a "Clean db" first, but that still didn't work. I had to uncheck all the media folders, save, scan, clean db, scan again, then recheck the media folders and scan. I may have done a bit of overkill on scanning with the folders unchecked but this fixed the problem.
Caution: You do lose your statistics when you do this.
Postby bushman4 » Tue Feb 26, 2013 4:14 pm
... and any comments.
Glenn
Glenn Sullivan
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby GJ51 » Tue Feb 26, 2013 4:21 pm
Yes - and I also think you lose any starred, hot, top rated, recently playes, and whatever else you have (some only apply to Madsonic), it's like doing a reinstall and starting over, just a bit less hassle.
Postby daneren2005 » Tue Feb 26, 2013 5:13 pm
I guess the reason I would consider that a terrible fix has nothing to do with the statistics, it has to do with losing all your playlists :(
Postby mbu10 » Tue Feb 26, 2013 5:49 pm
[url]
      [i][/i]
[/url]
mbu10
Postby mbu10 » Tue Feb 26, 2013 5:51 pm
opss keyboard went mad
anyway not lost
i renamed the subsonic folder and started again
but kept the folder
and i tried the fix did nto work
removed the tv show folder
cleaned db
then readded
did this 2 times one of the time i even gave it a diffrent name
but did not add the files, once i reset it it added it stright away
thanks
mbu10
Postby mbu10 » Tue Feb 26, 2013 6:05 pm
in addition to help this was not moving file
have a folder tv shows - in there is the name of every one ina folder - in that folder is season xx
i added some up to date tv shows into this folder
it was working up until the 22nd (last shows last added date) then would not add anymore
after deleted it, picked up the show nearly instantly
mbu
mbu10
Postby mbu10 » Tue Feb 26, 2013 6:44 pm
well just to solve this
have moved back to my old version of the subsonic folder
verifed can play videos all good and have set it away scanning again
want me to included the log file in here???
mbu10
Postby mbu10 » Tue Feb 26, 2013 6:54 pm
well swopped over
stop start service fine
rebooted box as does not go down very often just in case
it all started up fine
another scan
this time it picked it up
what gives ???
mbu10
Postby hakko » Tue Feb 26, 2013 8:39 pm
GJ51 wrote:Yes - and I also think you lose any starred, hot, top rated, recently playes, and whatever else you have (some only apply to Madsonic), it's like doing a reinstall and starting over, just a bit less hassle.
In MusicCabinet, I made the database design so that this information is not lost if you temporarily remove a folder, move folders and files around, transfer your database from one computer to another etc. The database keeps track of abstract information (names of artists, albums, tracks etc) and local occurrences of abstract information (a file with a tag referencing a certain track etc). Starred tracks, play statistic etc is tied to the abstract information, not to a certain file. I think this is an improvement if Sindre would like to pick it up for a future release.
hakko
Postby GJ51 » Tue Feb 26, 2013 9:12 pm
Sindre who?
