Subsonic For ICS Android 4.0
Re: Subsonic For ICS Android 4.0
Postby SubBurgundy » Fri Oct 19, 2012 2:59 am
disgustipated wrote:here is an edit to the last one
i changed a few of the default settings
cache size to 5gb
max bitrate mobile 128
buffer length 15
scrobble to last.fm on
keep screen on - not checked
songs to preload 5
FWIW I like this version much better than the latest "official" update in the play store. Thanks for sharing your work with the community here!
SubBurgundy
Postby disgustipated » Fri Oct 19, 2012 3:38 am
Thanks but i can't take any of the credit, it's mostly haxmatic,ttabal and others, I'm just a hack learning to mess with java.
disgustipated
Postby disgustipated » Fri Oct 19, 2012 3:41 am
I do have the star and un star almost working though,i feel it's kind of hacky so i don't want to post the source just yet
disgustipated
Postby dunnno » Tue Nov 06, 2012 7:16 am
Been using this custom app for ages and there are two points I'd like to be set :-)
1. I use the offline feature to listen to songs when I'm not connected (i.e in the subway), but those offline songs aren't scrobbled to last.fm. Even more, they are never scrobbled anymore since those songs doesn't require a connection with the server. So this server doesn't know it has to scrobble them. Maybe we (well, you, the programmers) add the scrobble feature to the Android for the offline songs.
2. Staying in that offline state, when I want to listen to offline songs, it's nowhere to find them unless you choose the offline button in the app first screen. Would it be possible to add the same way the Google Music app works?
Just asking huh ;-)
Envoyé depuis mon HTC Sensation avec Tapatalk
dunnno
Postby ttabbal » Wed Nov 07, 2012 4:28 am
I finally got some time to fool with code again. Here's a test build. I modified the BT handling a little to catch a lower level disconnect event. I also added the BT permissions, as it was throwing an error on my phone about not having permission to do a2dp stuff. In my testing, powering off the headset pauses the player properly. :D I haven't tested with anything other than my headset, so I need those of you that had issues with cars and such to help me test. Let me know what happens. Those were the only changes from my last build.
If you have logcat running, you should see this on disconnect: "NEW: Disconnected from Bluetooth A2DP, requesting pause."
ttabbal
Postby ttabbal » Wed Nov 07, 2012 4:55 am
Meh... Added the connect event, I noticed it wasn't firing. I don't know if it's needed as the media keys work, but it might be interesting to see...
ttabbal
Postby disgustipated » Sat Nov 10, 2012 3:51 pm
Ttabbal-have you seen the latest version in the play store... its fantastic. Have you seen the source for thatone yet? It looks like a huge visual refresh as well as a few fixes namely Bluetooth.
disgustipated
Postby disgustipated » Sat Nov 10, 2012 4:08 pm
Actually, i think i just found it on sourceforge. I'm going to have to play tonight, good thing too since i lost all of the source for the other stuff i did.
disgustipated
Postby ttabbal » Sat Nov 10, 2012 4:37 pm
disgustipated wrote:Ttabbal-have you seen the latest version in the play store... its fantastic. Have you seen the source for thatone yet? It looks like a huge visual refresh as well as a few fixes namely Bluetooth.
nope... I haven't looked at the official stuff in a while now. I'll have to grab it and see what's new.
ttabbal
Postby archrival » Fri Jan 25, 2013 9:09 am
I have made a number of modifications since my last release and I have started a new thread, please check it out. http://forum.subsonic.org/forum/viewtopic.php?f=8&t=11303
archrival
Postby pioneersohpioneers » Tue Feb 05, 2013 4:59 pm
Annnnnnnnnnnd my bad. Reposted in the correct thread.
Great update ArchRival!
There are a couple annoying bugs that I've found. If the music is paused, and I get any type of notification, subsonic starts playing after the notification has ended. I have to manually exit the app, or clear the playlist to stop this.
The other big issue I've noticed is that the app will hang the first time I open it after a while (think first launch after waking up in the morning). I have to wait until android asks if I want to force close the app, on next launch it works.
Lastly, I think the device is causing pretty constant wakelocks when playing music, but i'm not sure i'm interpreting BetterBatteryStats correctly. I've got AudioOut_2 , android.media.MediaPlayer and net.sourceforge.subsonic.androidapp.service.DownloadServiceImpl as Partial Wakelocks.
By the way, I'm running JB 4.2.1 on an HTC Rezound (IAmTheOneCalledNeo's Infectious Rezound ROM). I believe these issues are present in the stock App, so I'm thinking this is an issues with 4.2 compatibility? Are there any logs I can post for you, or anyway I can help out?
nickgw.subsonic.net
pioneersohpioneers
Previous
