Subsonic For ICS Android 4.0
Re: Subsonic For ICS Android 4.0
Postby DGMayor » Sun Feb 26, 2012 8:53 pm
haxzamatic wrote:
DGMayor wrote:Latest build looks great but the widget is messed up. Looks like it should be 4x1 but it's stretched into a 4x2.
I'm doing the widget and the player for the next build, also adding ICS lockscreen widget :)
Awesome. I only mentioned it because the widget changed from the last build so I wasn't sure if you had done something intentionally/accidentally or what.
DGMayor
Postby XJRodzx » Sun Feb 26, 2012 11:02 pm
haxzamatic wrote:
XJRodzx wrote:Is this supposed to work on GB? I keep getting FC's after installation. I know the thread title states "for ICS" but, the OP mentions it working on other Android versions.
Try the build I just posted, let me know how that works. Yeah this needs to work on all devices though.
Yep, that did it. Great job Hax
XJRodzx
Postby sgravel » Mon Feb 27, 2012 12:40 am
Hey it looks good!
Given that we have to uninstall to update to the newest build, which resets settings, what can I do next time to avoid losing most of my cached music? Had cache set to 10GB, and it's 500MB by default. The first time I launched it, I think it deleted about 3GB of music...
Sent from my Galaxy Nexus using Tapatalk
sgravel
Postby sgravel » Mon Feb 27, 2012 6:19 pm
Hey, the stuttering seems like it is gone on the new build 8-)
sgravel
Postby sgravel » Mon Feb 27, 2012 6:46 pm
Liking the "screen on" option too. Missed that after leaving the stock app for this one. Was it always there and I just didn't see it?
Do you plan to make the playback controls brighter in a future build? They are too dark to see in the car:
sgravel
Postby DGMayor » Mon Feb 27, 2012 10:21 pm
So fyi no skipping/stuttering on this new build!
DGMayor
Postby haxzamatic » Tue Feb 28, 2012 12:58 am
haxzamatic
Postby jsr » Tue Feb 28, 2012 1:10 am
Have you considered integrating my ICS style widget?
http://forum.subsonic.org/forum/viewtopic.php?f=8&t=8963
jsr
Postby DGMayor » Tue Feb 28, 2012 1:22 am
So I lied, had a skip/stutter. It's definitely less though.
DGMayor
Postby haxzamatic » Tue Feb 28, 2012 2:38 am
DGMayor wrote:So I lied, had a skip/stutter. It's definitely less though.
It won't stutter on cached songs, any song I click on that's not cached will stutter.
haxzamatic
Postby haxzamatic » Tue Feb 28, 2012 2:42 am
jsr wrote:Have you considered integrating my ICS style widget?
I'll add that to the next build for sure, I'll just include both.
haxzamatic
Postby haxzamatic » Tue Feb 28, 2012 2:47 am
sgravel wrote:Hey it looks good!
I'm sorry, I never thought that would happen. Make sure you backup before you go back to market version when this is done. I would just rename the "Subsonic" cache folder on your sd then after you install and set cache size change the name back?
haxzamatic
Postby olofmogren » Tue Feb 28, 2012 10:55 am
I have a couple of feature wishes for the android client
1. Caching of the library (listing) would save me some hassle. ISub on iphone has this.
2. Bookmarks so you can take up your listening where you left off. I use Subsonic both for music and audiobooks, and this would be very good for the audiobooks.
I could try to hack this myself, but unfortunately, I doubt that I will have enough time.
olofmogren
Re: Re: Subsonic For ICS Android 4.0
Postby sgravel » Tue Feb 28, 2012 1:51 pm
That was what I was thinking, but I did not know if there was more to it than that. Thanks.
By the way, if people are using ROMs or launchers that allow resizing of widgets that are normally not resizable, they should be able to reduce the size of the widget on the current build to make it look right. Worked for me.
sgravel
Re: Re: Re: Subsonic For ICS Android 4.0
Postby haxzamatic » Tue Feb 28, 2012 3:26 pm
olofmogren wrote:I have a couple of feature wishes for the android client
I plan on making a cached music tab, it's really needed. The bookmarks is a good idea, I'll put them on the to do list.
In the next build I made the widget resizeable on ics stock launcher and it's also 4x1 on ics by default.
haxzamatic
