How to refresh library?
Postby enedene » Sun Aug 26, 2012 1:10 pm
I've added some new albums, but they are not shown in the library, how should I refresh it?
enedene
Re: How to refresh library?
Postby hakko » Sun Aug 26, 2012 1:40 pm
Start a scan from Settings -> Media folders
MusicCabinet developer
hakko
Postby enedene » Sun Aug 26, 2012 2:08 pm
I'm using a stable 4.6 version, there is no such option:
enedene
Postby hakko » Sun Aug 26, 2012 2:15 pm
Hmm. 4.6 is supposed to pick up folder/file changes, I assumed 4.7 since it needs a scan. Do the albums appear if you remove/add the whole media folder they're in?
hakko
Postby enedene » Sun Aug 26, 2012 2:17 pm
hakko wrote:Hmm. 4.6 is supposed to pick up folder/file changes, I assumed 4.7 since it needs a scan. Do the albums appear if you remove/add the whole media folder they're in?
You're right, I apologize. The band name is "The Aristocrats" I was searching on letter "T" while it put the band to letter "A", which I actually like.
Thank you for your time anyway.
enedene
