music is being downloaded/cached to my Android phone
Postby somercamb » Tue Nov 06, 2012 12:17 pm
I saw this post, but they did not mention as to whether caching music on phone uses more data on top of simply just streaming music. Since I limited to 2GB of data per month I don't want Subsonic downloading/caching music to my phone, which I assume uses more data on top of just streaming the music?
Thank you
somercamb
Re: music is being downloaded/cached to my Android phone
Postby BKKKPewsey » Tue Nov 06, 2012 3:44 pm
somercamb wrote:which I assume uses more data on top of just streaming the music?
You assume wrongly - its the same
Cached just means that the music that has been streamed is saved to phone memory rather then discarded.
Postby somercamb » Tue Nov 06, 2012 3:51 pm
ok, so just to be clear...whatever is cached to the phone is the same data used for streaming? I do believe you, but what are your sources?
Thanks so much for the quick response
somercamb
Postby bushman4 » Tue Nov 06, 2012 6:37 pm
Yes, that is correct.
Our sources are multiple years using and volunteering our time to help support this product. That and the ability to read the source code of the application and see what it is doing.
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
