New Install - W2K3
New Install - W2K3
Postby breese » Sat Feb 21, 2009 1:19 pm
I have a W2K3 server and am currently using Jinzora.
I have a working web server on this machine with 3 web sites.
The current config is basicly
Web Server and Windows Media Server are installed
2 gig of ram and 2 raid 5's installed.
C: Boot
F: web sites area
G: backup area
I am looking to install Subsonic and am willing to test.
I would prefer to have as much of Subsonic on the Web Sites drive as possible.
I would also like to have / help with possibly getting Subsonic to communicate to my Media Server and do live playlist updates.
thanks for the time and I look forward to any suggestions and ideas on installing Subsonic.
breese
Postby braddyo » Mon Feb 23, 2009 6:44 am
I run Subsonic on IIS 7 (Vista) and it works great. Here is a thread that talks about it.
You need to keep the Subsonic program files in Program Files (you might be able to install them to a separate drive) but to move the subsonic web/active directory just read this thread.
braddyo
Postby donpearson » Tue Feb 24, 2009 7:15 pm
i run it on a W2K3 server using apache for a proxy, as far as i no you cant get subsonic to communicate to your media server
Just install it where it's ment to be, can i ask why you want it installed else where?
Facebook Group:
donpearson
Postby fuji0000 » Fri Apr 24, 2009 9:52 am
I just installed a Domain in my W2k3 server system, upgrading from workgroup. My sql guru mentioned I should have two network connections on myh server.
_________________
Call Center Software
fuji0000
Postby infocalypse » Wed May 06, 2009 10:44 pm
FWIW, you should be able to get Subsonic to pull/index music from your media server by simply providing the UNC path to the storage within subsonic... e.g \\musicserver\sharename
I've subsonic running in a windows 2003 VM, pulling it's music via UNC path from another Windows 2003 VM. Works great!
infocalypse
