Subsonic Minimum Specs
Postby Quickdood » Thu Jun 03, 2010 6:23 pm
I was thinking about buying an asus eee box with the below specs. I wanted to use this primarily as a subsonic server switching from my Linux box which runs hot and uses tons of energy. Does anyone know if this computer would be capable of running subsonic well? It would have to trans-code for 3 other users than myself at the same time.
General Spec
Brand ASUS
Series Eee Box
Model EB1006-W-111-5002
Type Home / Home Office
Colors White
Processor Intel Atom N270(1.6GHz)
Cache Per Processor 512KB L2 Cache
Memory 1GB DDR2
Hard Drive 160GB 5400rpm
Graphics ATI Radeon HD 4530, 256MB DDRII
Audio Sound card - Integrated
Ethernet 10/100/1000 Mbps
Wireless Card 802.11 b/g/n Wireless LAN
Keyboard Wireless KeyBoard
Mouse Wireless Mouse
Operating System Windows XP Home
Motherboard
Chipset Intel 945GSE
CPU
CPU Type Intel Atom
Installed Qty 1
CPU FSB 533MHz
CPU Speed N270(1.60GHz)
L2 Cache Per CPU 512KB
Graphics
GPU/VPU Type ATI Radeon HD 4530
Memory
Memory Capacity 1GB DDR2
Form Factor SoDIMM 200-pin
Memory Spec 1GB x 1
Memory Slot (Total) 1
Memory Slot (Available) 0
Maximum Memory Supported 2GB
Quickdood
hola
Postby buellie » Thu Jun 03, 2010 7:23 pm
im running it on a dell inspiron 1525 notebook
thats got a busted moniter hinge and 1 processor turned off to keep it running cooler
cause if you enable 2 processor it shuts off cause it runs too hot...my daughter tossed
the POS for a new toshiba cause it kept overheating
im running Linux Mint 7 as the OS
buellie
Postby Quickdood » Thu Jun 03, 2010 7:34 pm
Thanks for the feedback. Looks like Subsonic doesn't need much to run.
Quickdood
Postby einsteinx2 » Fri Jun 04, 2010 6:48 am
Ya Subsonic will run on almost anything. It just needs around 100+ megs of ram depending on the size of your music collection and enough hard drive space for your music (or it could even use music right off a network share). Doesn't need a fast processor or even a monitor.
I <3 Subsonic :D
einsteinx2
hi
Postby sweet12 » Sat Jun 12, 2010 2:50 am
You are free to delete shortcuts pointing to it from a Start Menu, but that's about it.
_________________
glee seasons 1-2 dvd boxset
glee 1-2
sweet12
Postby subssonic_rox » Sat Jun 12, 2010 5:36 pm
I have run 120+gb music library on a p3/550 with 512mb ram on Ubuntu 9 and it did fine. It was the only app on the machine on a FIOS 15/5 internet pipe. Had up to 5 people on it @ once all running aes encrypted ssh tunnels to it. Windowz is going to require more ram to be as efficient as linux but a gig should work fine. The more the better obviously. Currently running it on a pos headless eMachine p4 with a gig of ram and it's much better so you should be fine.
Have fun. Subsonic is awesome.
subssonic_rox
