plowman wrote:Just to clarify what j3tblk stated:
If your device is connected to your LAN (either wireless or wired) and NOT using 3G then the initial handshake and such (DNS lookup, etc.) will query the internet at large. However, even if you are using the externally facing address (something.subsonic.org) the data traffic will just HIT your router. It will not be pushing that streamed content data out to the internet and back. It will never really "leave" your LAN. Still all high-speed and such (given that most wireless routers will impose some serious limitations to LAN traffic speeds due their meager imbedded hardware).
Josh Hawley wrote:The DNS packets do go out onto the internet. They are only part of the initial connection process though.
Because the router is the delineation between the internet and your private lan, it is technically going on the internet. However, I bet if you look a little deeper you will find that your packets are going through the outbound NAT/ACL/etc then the interface send the packets to the proper IP (which is the external IP of the router) and then through the inbound NAT/ACL/etc. It is connecting to itself. So they don't go out onto the internet enough to be subject to any real security issues, and they do not consume your internet bandwidth because they are not going across any WAN links.
Your packets are about as public as your front porch. Its like you start in the living room, and step out onto the front porch and then back inside on the way to your kitchen.
