[HowTo] Database broken : Import old settings
Tutorials, tips and tricks.
Re: [HowTo] Database broken : Import old settings
Postby pabohoney1 » Wed Dec 26, 2012 9:50 pm
So I recently had to recover from a DB corruption. Found this post on how to reimport users and settings. The problem I was running into is the same as above, it says a duplicate value is found. Normally with a SQL query, you can use REPLACE if the value is found, but that doesn't seem to work with the subsonic db query page. Any ideas from anyone?
pabohoney1
Postby hakko » Wed Dec 26, 2012 10:01 pm
Do you mean UPDATE?
MusicCabinet developer
hakko
Postby Pessoa » Sat Dec 29, 2012 5:30 am
Thanks a lot for your help! I've got it working again perfectly and understand the system a lot better too.
Pessoa
Postby Pessoa » Sat Dec 29, 2012 5:31 am
thanks for your help!
Pessoa
Previous
Return to Tutorials
