How to play my music on another computer?
Tutorials, tips and tricks.
Postby Larsen » Thu Sep 03, 2009 2:42 pm
Hi, have installed subsonic on my computer, but can't find out how to log on from another computer, do I have to install subsonic on the other computer to? :S
Larsen
Postby buellie » Thu Sep 03, 2009 5:04 pm
If Your Trying To Log In Internally From Then You Would Point Your Browser To Something Like http://x.x.x.x:Port Number
http://192.168.1.160:8080
If Your Trying To Log In Outside Your Network Then You Need To Find Your IP Address And Logging In Would Be Something Like:
http://67.29.44.108:8080
Make Sure To Port Forward Your Router To Allow Access To Whatever Port You Have Open In Subsonic And Also If Your Using Windows, Make Sure That Windows Firewall Also Allows Access To Either Subsonic Or Whatever Port Subsonic Is Using
Hope This Helps
buellie
Postby cielo_wii » Thu Sep 17, 2009 6:37 am
this is my problem too.... i tried it
but still not working... how come???
maybe there's something wrong...
i'll try it again... thanks for this...
cielo_wii
Postby semtex41 » Thu Sep 24, 2009 2:11 pm
You probably need to configure port forwarding in your router.
Locate the brand/model of router and with a quick google search you should be able to find the manufacturer's manual. It will instruct you how to accomplish this.
semtex41
Postby 3R3 » Wed Mar 10, 2010 3:27 pm
and for sake of completeness, and for anyone coming from google, heres the comprehensive guide on how to access subsonic remotely
3R3
Return to Tutorials
