New Folder access tocertain Users not all
Frequently asked questions.
Postby jgraythe4th » Sat Sep 09, 2017 5:05 pm
Is there a way to add a folder, under the Media Folder tab in settings, where that it does NOT give all my users access to it. I want to be able to add a folder and add Users to the folder individually.
jgraythe4th
Re: New Folder access tocertain Users not all
Postby Michael Bech Hansen » Sat Sep 09, 2017 8:43 pm
It seems that new media folders by default are available to all existing users...
So you will have to disallow access to the new media folder for each user that should not have access:
- Login to server web interface as admin
- Goto Subsonic settings -> Users
- For each user uncheck the appropriate media folder(s)
Developer of play:Sub for iOS.
https://geo.itunes.apple.com/us/app/play-sub-subsonic-music-streamer/id955329386?mt=8
Michael Bech Hansen
Postby audiosteve » Mon Oct 22, 2018 11:30 pm
Can anyone answer this? It is my largest management headache. Id I add a folder how do I set things up so everyone doesn't auctoamitcally have access to it (and all others as well when adding a person)
audiosteve
Postby J_T_W » Tue Oct 23, 2018 7:32 pm
I don't believe you can do this at a sub-folder level, only at a root media folder level, then per-user.
J_T_W
Postby audiosteve » Tue Oct 23, 2018 8:09 pm
Thanks for your reply, but... do you believe this can't be done or do you know it can't be done?
There has to be script change that can un check all the boxes, instead of checking them, be default.
Unfortunately I don't know enough to know where the script is saved or what to change.
I'll poke around and see what I can find. But if anyone out there knows......
thanx
audiosteve
Postby J_T_W » Tue Oct 23, 2018 9:48 pm
I don't know about scripting, but you might be able to manage something via the <installdir>\data\db\subsonic.script (if you're on Windows), or if it isn't that frequent, perhaps manual manipulation via the http://<server:4040>/db.view SQL query window could be useful. A quick query to identify tables/fields is:
SELECT TABLE_NAME, COLUMN_NAME, TYPE_NAME, IS_NULLABLE FROM INFORMATION_SCHEMA.SYSTEM_COLUMNS WHERE TABLE_NAME NOT LIKE 'SYSTEM_%'
J_T_W
Postby audiosteve » Tue Oct 23, 2018 11:42 pm
Thanks for the tip. That all looks like database stuff, not presentation options. That would only be relevant if a new user had a default database entry with default values set. I'll look closer.
BTW, those files you referenced are in var/subsonic/db on the linux distro I am using.
audiosteve
Postby clarkc055 » Sat Feb 08, 2020 6:20 pm
clarkc055
Return to FAQs
