will it still run after 30 days? [Solved]
Frequently asked questions.
Postby kento » Sun Jun 05, 2011 7:44 am
hi will subsonic still be working all the way after lets say 30 days or do i need to donate money at that time to continue using the SS??
greetings
kento
kento
Postby fonsoy » Sun Jun 05, 2011 2:54 pm
Just to use the web player you can use it continuously, but to use the API you will have to "donate". (E.G. for mobile devices, support only lasts 30 days).
fonsoy
Postby kento » Sun Jun 05, 2011 2:57 pm
fonsoy wrote:Just to use the web player you can use it continuously, but to use the API you will have to "donate". (E.G. for mobile devices, support only lasts 30 days).
not surre what you mean? can i still use it as now? or will the server close and such?
i mean i use the software as i is after install and only use the player so i can use my winamp for playing part. will that stop after the 30 days?
ill save up some money so i can donate, but on danish pension thats gonna take some time though. :)
kento
Postby OlYeller21 » Sun Jun 05, 2011 11:48 pm
The only thing you pay for after 30 days is to get/keep a <name>.subsonic.org address which is not needed to use subsonic; it just makes accessing it a little easier.
Without the redirect (the <name>.subsonic.org address) you can still access your server using your IP address. If you're on the same network, it would look something like "http://192.168.1.101/index.view" (the internal IP address of the computer running Subsonic) depending on what type of router you use. If you're outside of your network, it would use your external IP address as look something like "http://71.71.245.167/index.view" (that's not my address).
I suggest donating but that's just me. Subsonic is pretty awesome and if you keep using it, it would be nice to throw Sindre (the lone creator) a few bucks.
OlYeller21
Postby kento » Mon Jun 06, 2011 3:40 am
OlYeller21 wrote:The only thing you pay for after 30 days is to get/keep a <name>.subsonic.org address which is not needed to use subsonic; it just makes accessing it a little easier.
Thanx for the help :) and yes i will donate infact... just have to save up the money first (takes a bit of time when on pension, but can be done though). :lol:
Got it solved by a nice person that helped me with donation, so it all runs big time now. :lol:
kento
Postby bushman4 » Tue Jun 07, 2011 2:02 pm
Just to be clear, the other thing you lose after 30 days (besides the use of CustomName.subsonic.org) is the REST API which ALL non-native apps (iPhone, Android, C#, AubAir, etc...) rely on.
So you will ONLY have access to the web interface after 30 days.
HTH,
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby OlYeller21 » Mon Jun 13, 2011 1:46 am
bushman4 wrote:Just to be clear, the other thing you lose after 30 days (besides the use of CustomName.subsonic.org) is the REST API which ALL non-native apps (iPhone, Android, C#, AubAir, etc...) rely on.
HTH,
Glenn
Never knew that. I guess it doesn't matter for me but it's good to know. Thanks.
OlYeller21
Return to FAQs
