Stream to a website
Frequently asked questions.
Stream to a website
Postby brianjs » Wed Jul 27, 2011 7:10 pm
Can Subsonic be modified to or does it have the ability to stream music to a player embedded on a website?
brianjs
Re: Stream to a website
Postby chongopants » Wed Jan 18, 2012 8:39 pm
I don't know for sure, I didn't code this. But you are looking for the 'embedding' option. So it is highly unlikely unless you did it yourself.
chongopants
Postby bobdylansdead » Mon Feb 13, 2012 3:35 am
I haven't tried this, but you could probably use the share function and publicly share the media, then iframe the player from that page on another site.
Probably not a perfect solution, but it would probably work.
bobdylansdead
Postby ytechie » Mon Feb 13, 2012 7:01 pm
You could use the share function, then grab the stream URL and use it wherever you want. Try it out. Tell me if it works. :D
ytechie
Return to FAQs
