Similar Artists Javascript Widget Mod
Re: Similar Artists Javascript Widget Mod
Postby Hellscream » Thu Dec 29, 2011 5:33 pm
hm i think u are expirienced f5 curse from sa widget O:-) sometimes i need to refresh page few times till everithing start to function again but after latest update its very rare but still present.
Hellscream
Postby mqchen » Fri Dec 30, 2011 3:30 am
@Pcace
If you could open up either Firebug or Inspector in Chrome and show us both the Console and the Network tabs it would be much easier to see what's wrong. (Also try the standard turn-it-on-and-off-again, the subsonic server, that is)
mqchen
Postby pemholder » Sat Dec 31, 2011 6:38 pm
@mqchen
Thanks for this greeat mod.
Is it possible to change the search fuction, if you click on the similar artists?
Example: I play a song from "Albert King". Similar artists suggests "Albert Collins". If I click on "Albert Collins" I get listed all songs and albums with "Albert" and "Collins" in artist name and song title, i.e. "Judy Collins", "Albert goes West" by Nick Cave and so on.
Clicking on a similar artist should only produce results that match the whole string and only search for artists. If I fill the search field of subsonic it searchs for the whole string and does not list search results for partial items.
pemholder
Postby Hellscream » Sat Dec 31, 2011 6:40 pm
@mqchen
Hi, this is the error happened sometimes solution is refreshing page few times
Hellscream
Postby BKKKPewsey » Sat Dec 31, 2011 8:35 pm
Only if you surround the search criteria in quotes - if you don't you will get partial searches.
That is another un-documented feature of SS which I discovered some time ago - useful to get partly around the 25 item search limit eg remove unwanted items.
If I search for "King Crimson" I will only get them and no B B King, Crimson Sky, etc cluttering up the results.
Postby Hellscream » Sat Dec 31, 2011 8:40 pm
ooooo thx m8 very usefull info
cheers
Hellscream
Postby pemholder » Sat Dec 31, 2011 10:19 pm
BKKKPewsey wrote:Only if you surround the search criteria in quotes - if you don't you will get partial searches.
Yes, but this is usual behaviour. I am so accustomed to do this, that I did not mention it.
The problem: I don't know wether and if possible where I can change the code in some place of the widget mod to change this behaviour.
pemholder
Postby Ataraxiainc » Sun Jan 08, 2012 12:13 pm
Hi. The Mod Is Great!! is very useful for me at least. But In 4.6 Not Work. Can You PLease review the code?. O Help me in a solution.
Many Thanks. I will appreciate your answer
Ataraxiainc
Postby Ataraxiainc » Sun Jan 08, 2012 12:34 pm
Ataraxiainc wrote:Hi. The Mod Is Great!! is very useful for me at least. But In 4.6 Not Work. Can You PLease review the code?. O Help me in a solution.
Jeje... I Deleted the Chrome cache and ... Abracadabra.!! Many thanks.
Ataraxiainc
Postby Cook66 » Fri Jan 13, 2012 4:59 pm
I can't get this to work. I installed in according to the instructions, but it doesn't show up in Subsonic.
Can anyone help me?
The Server is running W7 64bit
The Client is running W7 64bit - tried IE9,FF9, Chrome something.
No errors as far as I can see. Nothing seems to have happend.
Edit:
After refreshing a bunch of times it appeared. Seems like the javascript is a bit unstable. Perhaps it times out or something?
This is awesome while it works by the way. I love it! :D
Cook66
Postby stratosrv » Sat Jun 02, 2012 9:15 am
Hi Guys..
Someone have tutorial of this installation in Freenas 7 please?
I have try to install the mod in freenas but without success.
stratosrv
Postby BKKKPewsey » Wed Jul 11, 2012 1:12 pm
Could any other users of this great mod confirm that it has recently (yesterday) stopped working?
I assume that it may be due to problems at the Last FM end as another script I use, in MM, also stopped working briefly yesterday and that accesses Last FM as well.
When going directly to the Last FM page I received a very strange page just showing the word ERROR which I think was generated by their database engine
and they now request a change in password whilst they sort out "security issues"
So it looks like they got hacked :?
However I can see from my sig that the scrobble side appears to working np. :)
Postby mqchen » Wed Jul 11, 2012 2:39 pm
I don't use Subsonic anymore so I don't know if it works or not, but the server component is at least still functioning, and it should be responsible to doing all the Last.fm and MusicBrainz communication. If you have setup your own server (the PHP part), could that be down?
mqchen
Postby BKKKPewsey » Wed Jul 11, 2012 4:14 pm
mqchen wrote:but the server component is at least still functioning,
I am going to put that down to a temporary "glitch" with the Last FM end - I changed the url to point to your server
It worked :)
Changed back to point to my own server - it works :?
Previous
