Another frontend, need opinions (beta release)
Postby oeh » Fri Jun 25, 2010 8:06 pm
Wow, this is just awesome.
Just can't wait for the release.
Any chance for beta testing? :lol:
Regards
OEH ;-}
oeh
Postby brett » Fri Jun 25, 2010 8:16 pm
oeh wrote:Image
I'll try to get a page up with install details/instructions this weekend
brett
Postby ThunderStick » Sat Jun 26, 2010 3:12 am
Love it cant wait for a release
ThunderStick
Postby driveonparkways » Sat Jun 26, 2010 2:36 pm
Very cool idea. Does it run quickly?
I'll be watching to see when you make it available!
driveonparkways
Postby brett » Mon Jun 28, 2010 1:59 am
driveonparkways wrote:Very cool idea. Does it run quickly?
Sure it runs quickly, I have had some weird issues getting auto-start to work with different version of JW player, but I think I've hammered out most of the bugs, I've also added video support, updated the pics on the main page. Once I get a decent looking UI to surround the main video screen I'll put out some details on how to get it setup. The main problem I can already see is this script is written for my folder layout/subsonic setup, its going to take a flawless setup script to tune it for each user.
brett
Postby Vproduct » Mon Jun 28, 2010 9:42 pm
Yes!!!! I want it!!!
Vproduct
Postby jeremy » Wed Jun 30, 2010 4:48 pm
i love it :D
hope you make it public soon :D.
jeremy
Postby Sh4gr4th » Fri Jul 02, 2010 11:10 pm
Did I really read "Drag and drop sort for the playlist"?
You are telling me, that I would be able to drag the last file and drop it to 2nd position? I won't have to click 15 times in order to have that song played next?
This would be so big.
Pleeease, releeease :)
Sh4gr4th
Postby brett » Tue Jul 06, 2010 10:22 pm
Yes, drag and drop in the playlist is functional, I've also added an option in the right click menu to just pick a position to move it to. I ran into a problem saving playlists when they get to a certain length(I believe it's based on maximum http request length), although I've managed to save a playlist containing 300+ files, so it shouldn't be a problem for most users. Loading a playlist with almost 500 files is not a problem.
I'm close to finishing up the setup script which will create the sql databases and write a settings file based on user input.
brett
Postby oeh » Wed Jul 07, 2010 12:40 am
Got a db as follows:
1,096 artists
1,124 albums
13,650 songs
235.47 GB (~ 3,657 hours)
Think this will be a problem?
Regards
OEH ;-}
oeh
Postby brett » Wed Jul 07, 2010 1:22 am
oeh wrote:Got a db as follows:
1,096 artists
1,124 albums
13,650 songs
The problem I was experiencing was related to playlists(to be specific the amount of songs you can send to be saved through the API at one time) as per the API here , unless I'm missing something, you have to send all songId's in one request for saving a single playlist. When you have a playlist that you want to save with 500 songs and the songId's are at least 10-15 characters in length you wind up with a massive url string.
If performance becomes an issue because there are too many artists on the left hand side I'm sure there will be a way to slim the display down. My album list has around 350 displayed in the primary view(I think I'm around 540 total) and it has no problems.
brett
Postby jeremy » Wed Jul 07, 2010 10:55 am
that setup script... is windows based ?
cause many users here use freebsd/linux :P
a nice sh script would be nice.
and the required packages :P
but.. very very nice work ! im really impressed :P
jeremy
Postby brett » Thu Jul 08, 2010 6:06 am
jeremy wrote:that setup script... is windows based ?
setup script is in php, just gotta goto it from a computer on the local network and it should setup all the variables/tables
brett
Postby jeremy » Thu Jul 08, 2010 10:24 am
oh okay that would be simple. and easy cross platform :P
jeremy
Postby mason » Fri Jul 09, 2010 5:42 pm
can't wait to give it a try, a makeover is overdue :)
mason
Users browsing this forum: Majestic-12 [Bot] and 12 guests
