Release: HomeView - CarouselMod (Updated)
What Screen Resolution do you prefer for Subsonic/CarouselMod?
1024x768
3
14%
1280x1024
4
18%
1440x900
2
9%
1920x1080
9
41%
bigger
4
18%
Total votes : 22
Re: Pre-Release: HomeView - CarouselMod
Postby Hellscream » Sat Feb 11, 2012 5:03 pm
Work like a charm :D
Keep with good work +++
Hellscream
Postby MadEvil » Sun Feb 12, 2012 8:09 am
Hellscream wrote:Work like a charm :D
Looks great :D
Best regards
Madsonic Developer
MadEvil
Postby Hellscream » Sun Feb 12, 2012 7:13 pm
It would be awesome to add album folders on carousel.
Hope you will do that :D.
Hellscream
Postby SparkyRih » Sun Feb 12, 2012 11:00 pm
Isn't it possible tadd this carousel later (after install of subsonic)?
VMWare ESXi 5.5 > Ubuntu 16.04 > Subsonic 6.0 (Modded with PHP based registration feature)
SparkyRih
Postby MadEvil » Mon Feb 13, 2012 7:56 am
SparkyRih wrote:Isn't it possible tadd this carousel later (after install of subsonic)?
if you want it to mod yourself - try this Files -> viewtopic.php?f=8&t=8918#p37267
Best Regards
Madsonic Developer
MadEvil
Postby Hellscream » Thu Feb 16, 2012 8:31 pm
Is it possible for carousel to display newest instead of random albums?
Hellscream
Postby SparkyRih » Thu Feb 16, 2012 9:25 pm
So I guess it won't work on SS 4.4?
I try to mod it manually, but nothing happens (nothing is even messed up in any way :P )..
SparkyRih
Postby Hellscream » Thu Feb 16, 2012 9:39 pm
bytethdgroove wrote:got it working....yeah :).......looks great
anyway to have an option of how many albums to display?
thanks
byte
If you change in drop down many number of albums to be displayed on for example random tab, carousel window will also be affected. :P
Hellscream
Postby Hellscream » Thu Feb 16, 2012 9:45 pm
SparkyRih wrote:So I guess it won't work on SS 4.4?
Thats strange, can you post home.jsp here
Hellscream
Postby SparkyRih » Thu Feb 16, 2012 10:27 pm
I've cleaned up and upgraded my SS... I guess I will try again tomorrow...
SparkyRih
Postby MadEvil » Thu Feb 16, 2012 10:58 pm
thanks
byte
hi,
here is a version where you can select how much albums do you want to view!
subsonic-4.6.B2585E-Modfilesv2.zip
best regards
Madsonic Developer
MadEvil
Re: Release: HomeView - CarouselMod
Postby SparkyRih » Fri Feb 17, 2012 1:19 pm
Ok now I getting pissed off... my server (in general) is messing with everything I do since yesterday.. now everythign is fine again... but now this carousel won't work at all??
Nothing happens if I replace the files??
SparkyRih
Postby MadEvil » Fri Feb 17, 2012 1:31 pm
SparkyRih wrote:Ok now I getting pissed off... my server (in general) is messing with everything I do since yesterday.. now everythign is fine again... but now this carousel won't work at all??
what Version do you have installed latest SS 4.6 ?
try this steps to complete:
1. stop server
2. Backup complete SS folder
3. clear your Internet browsers cache AND cookies
4. clear (delete) subsonics internal cache (the jetty cache is at subsonic/jetty/<num>/jsp/org/apache/jsp/WEB_002dINF
5. edit/replace servers files to be modded
6. restart server
7. restart browser
I think this should help! :wink:
Best regards
Madsonic Developer
MadEvil
Postby SparkyRih » Fri Feb 17, 2012 1:37 pm
Yeah I did all that... but I see, I had to select the hot tab? how do I set it as default??
SparkyRih
Postby MadEvil » Fri Feb 17, 2012 2:19 pm
SparkyRih wrote:Yeah I did all that... but I see, I had to select the hot tab? how do I set it as default??
edit the code-block in top.jsp file
from
<td style="min-width:4em;padding-right:1.5em">
<a href="home.view?" target="main"><img src="<spring:theme code="homeImage"/>" title="${home}" alt="${home}"></a><br>
<a href="home.view?" target="main">${home}</a>
</td>
to
<a href="home.view?listType=hot" target="main"><img src="<spring:theme code="homeImage"/>" title="${home}" alt="${home}"></a><br>
<a href="home.view?listType=hot" target="main">${home}</a>
</td>
Hope this will help you! Dont forget to clear cache or reload/refresh Page/Frame within your Browser!!
Madsonic Developer
MadEvil
