Subsonic Pack version 4.4- 2172
Postby cyclopes » Wed Jun 08, 2011 9:50 pm
muiz wrote:I have lowered the player for the EQ , but now i want the rest lower to.
look for this in playlist.jsp
<td valign="bottom" style=
and add this in
<td valign="bottom" style=height:35px;........
[/b]
Vote Confirmation ;)
cyclopes
Postby muiz » Fri Jun 10, 2011 3:05 pm
no such thing in my playlist.jsp :(
muiz
Postby cyclopes » Fri Jun 10, 2011 11:47 pm
muiz wrote:no such thing in my playlist.jsp :(
download this file.
http://ferietunet.no/subsonic/playlist.zip
This is width equlaizer
open and look the file and you see what you have to change in playlist.jsp :)
cyclopes
Postby muiz » Mon Jun 13, 2011 1:31 am
thx that worked :P
muiz
Postby Hellscream » Sun Jun 26, 2011 5:46 pm
Awesome Pack working fine +++++++
Hellscream
Player is blank
Postby trickydick » Fri Jul 01, 2011 1:36 am
i changed like the text file said...moded the xml, jsp and css. open each jsp in notepad and saved it. restarted services. when i log in, my player is missing. just the replacement icons are there (shuffle, repeat, etc). I litterly have a white box where it the flash player is suppoed to be. what could it be?
trickydick
Running beta
Postby trickydick » Fri Jul 01, 2011 1:49 am
i found out why. my version of the flash player is jw-player-5.6.swf, this one is pointing to jw-player-5.4.swf. I remembered i changed it to the 4.5beta1...once i modified the code to use the new player it work great. love it. thanks
Tricky
trickydick
Themes for all!
Postby trickydick » Fri Jul 01, 2011 2:59 am
What about all the other themes. have you thought of making different color scheme for each theme available in subsonic, instead of use just silver/dark. This shoudn't be to difficult; modify the theme.properties for each theme and css. Do you have the orginal source code for your images (photoshop, jasc, etc)? I would like to mod them and build the player buttons for each theme.
Tricky
trickydick
Make it work with each theme
Postby trickydick » Fri Jul 01, 2011 4:30 am
I love the idea, but I had to modify it just a little to make it work seamlessly with each theme.
Here is how:
I am currently working on all the player colors for each theme,but for now you will have to copy the silver or black images to the root\icons\theme folders. Don;t rename them (the shouldn't overwrite any originals.
Next you will have to modiify each css file for each theme in subsonic.. Just add this to the bottom:
/* Player images*/
a#rewind1 {
background-image:url("../icons/midnight/rewind1.png");background-position: 0px 0px; background-repeat:no-repeat; height: 24px; width: 23px; display:block;text-indent: -9999px;}
a#forward1 {
background-image:url("../icons/midnight/forward1.png");background-position: 0px 0px; background-repeat:no-repeat; height: 24px; width: 23px; display:block;text-indent: -9999px;}
a#clear1 {
background-image:url("../icons/midnight/clear1.png");background-position: 0px 0px; background-repeat:no-repeat; height: 24px; width: 23px; display:block;text-indent: -9999px;
a#shuffle {
background-image:url("../icons/midnight/shuffle.png");background-position: 0px 0px; background-repeat:no-repeat; height: 24px; width: 23px; display:block;text-indent: -9999px;}
a#repeat_on {
background-image:url("../icons/midnight/repeat_on.png");background-position: 0px 0px; background-repeat:no-repeat; height: 24px; width: 23px; display:block;text-indent: -9999px;}
a#repeat_off {
background-image:url("../icons/midnight/repeat_off.png");background-position: 0px 0px; background-repeat:no-repeat; height: 24px; width: 23px; display:block;text-indent: -9999px;}
a#undo {
background-image:url("../icons/midnight/undo.png");background-position: 0px 0px; background-repeat:no-repeat; height: 24px; width: 23px; display:block;text-indent: -9999px;}
a#settings1 {
background-image:url("../icons/midnight/settings1.png");background-position: 0px 0px; background-repeat:no-repeat; height: 24px; width: 23px; display:block;text-indent: -9999px;}
Next....open playlist.jsp and replace the playes section with this:
<c:if test="${model.player.web}">
<td style="white-space:nowrap;"><a href="javascript:noop()" onClick="onPrevious()" id="rewind1">Rewind</a></td>
<td style="white-space:nowrap;"><a href="javascript:noop()" onClick="onNext(false)" id="forward1">Forward</a></td>
</c:if>
<a href="javascript:noop()" onClick="onClear()" id="clear1">Clear</a>
</td>
<td style="white-space:nowrap;"><a href="javascript:noop()" onClick="onShuffle()" id="shuffle">Shuffle</a></td>
<c:if test="${model.player.web or model.player.jukebox or model.player.external}">
<td style="white-space:nowrap;"><span id="bobcontent1-title" class="handcursor"></span><div id="bobcontent1" class="switchgroup1"></div>
<script type="text/javascript">
// MAIN FUNCTION: new switchcontent("class name", "[optional_element_type_to_scan_for]") REQUIRED
// Call Instance.init() at the very end. REQUIRED
var bobexample=new switchcontent("switchgroup1", "div") //Limit scanning of switch contents to just "div" elements
bobexample.setStatus('<a href="javascript:noop()" onClick="onToggleRepeat()" id="repeat_on" /> ', '<a href="javascript:noop()" onClick="onToggleRepeat()" id="repeat_off" /> ')
bobexample.setColor('darkred', 'black')
bobexample.setPersist(true)
bobexample.collapsePrevious(true) //Only one content open at any given time
bobexample.init()
</script></a></td>
</c:if>
<td style="white-space:nowrap;"><a href="javascript:noop()" onClick="onUndo()" id="undo">undo</a></td>
<c:if test="${model.user.settingsRole}">
<td style="white-space:nowrap;"><a href="playerSettings.view?id=${model.player.id}" target="main" id="settings1">settings</a></td>
</c:if>
Thats it, now no matter what theme your users select they will get the correct player colors.
Soon i will provide source images for each theme (they are slightly different colors). Enjoy
Tricky
trickydick
Postby muiz » Sat Jul 16, 2011 11:58 am
can you explain this some more, dont get it.
muiz
playermod
Postby trickydick » Tue Aug 02, 2011 7:50 pm
try my playermod; it does the same thing:
http://forum.subsonic.org/forum/viewtopic.php?t=7155
Tricky
trickydick
Postby muiz » Tue Aug 02, 2011 9:03 pm
time for an update for 4.5
muiz
4.5 supported
Postby trickydick » Wed Aug 03, 2011 1:04 pm
the player mod now supports SS 4.5 beta 2. (release 3.2)
Tricky
trickydick
Re: Subsonic Pack version 4.4- 2172
Postby muiz » Tue Jan 24, 2012 10:15 pm
4.6 ? :oops:
muiz
Previous
Users browsing this forum: No registered users and 42 guests
