Subsonic Player Mod
Subsonic Player Mod
Postby trickydick » Mon Jul 04, 2011 5:47 am
Here is my first mod based on cyclopes subsonic pack idea. There is no upload area, just changes the player to display buttons (images instead of links....and it will change to the colors in each subsonic theme including the buuftheme. Works great!!!
*special thanks to cyclopes.
https://docs.google.com/leaf?id=0B1iBWlUz8eUkZWJjMjA3NTQtMjk2NS00MTFkLTk4MGUtNzc2NWJkYjY2YTll&hl=en_US
Try it out and let me know what you think.
Tricky
trickydick
Postby muiz » Sat Jul 16, 2011 11:48 am
screenshot?
muiz
Playermod 2.0
Postby trickydick » Wed Jul 27, 2011 3:55 am
This mod (version 2.0) changes the more actions dropdown to icons. This mod is not resizable yet. I am working on the next one to be able to change the player based on resolution, so the user gets all options on a smaller screen.
This will change based on what theme is used. Does support all subsonic themes plus BUFF theme:
If you use my outlook theme (http://forum.subsonic.org/forum/viewtopic.php?t=7238), it will also support it along with a few cosmetic changes
Tricky
trickydick
Download version 2.5
Postby trickydick » Thu Jul 28, 2011 4:01 am
Here is the next version of this player mod (2.5). it incorporates an advanced menu now. This is for users with lower resolution screens
Download it:
https://docs.google.com/viewer?a=v&pid=explorer&chrome=true&srcid=0B1iBWlUz8eUkMjlhNjAxYjEtNzE0Yy00YWFkLWJmYjgtZGUxZjllZmE0NGMy&hl=en_US
Tricky
trickydick
Postby sergiocos » Thu Jul 28, 2011 10:35 am
Download link ONLY for 2.0? I use a lower res, so my player is now crippled a little :)
http://imageshack.us/photo/my-images/83 ... d01wc.jpg/
Still, it looks amazing, congrats on Outlook theme and this player mod!
LE: sorted now... probably a cache thing ;)
sergiocos
info
Postby trickydick » Thu Jul 28, 2011 9:13 pm
can u tell me which browser u are using and what resolution your at? this should be an easy fix; just a change to some CSS margins. thanks
Tricky
trickydick
Postby sergiocos » Fri Jul 29, 2011 1:31 pm
1360x768, FF5
sergiocos
Postby muiz » Sun Jul 31, 2011 2:59 pm
can you please zip/rar the file and upload somewhere?
cant download with your link, downloading all files one by one is a bit to much....
looks great by the way cant wait to try
muiz
Postby Hellscream » Mon Aug 01, 2011 11:18 am
I've already try and its amassing but have few issues with gif images (up and down arrows) and i use 1680x1050 still not in same line
Hellscream
Postby Hellscream » Tue Aug 02, 2011 9:26 am
Here is a little fix for player in (playlist file) for ppl who like everything to bee in line.
<div class="solidblockmenu-outer" style="margin-top:1px;">
chnge line 461 in playlist file:
<div class="solidblockmenu-outer" style="margin-top:5px;">
thx again for amazing mod keep with good work[/code]
Hellscream
Version 3.1
Postby trickydick » Tue Aug 02, 2011 7:25 pm
So I updated the mod with hellscreems fix and it will also support beta 2 if you have that installed.
BETA 2 NOTE:
Beta 2 must be installed first. Backup your playlist.jsp, yhen you must rename the playlist-beta2.jsp to playlist.jsp. This will add a music icon in the advanced menu for sharing.
https://docs.google.com/viewer?a=v&pid=explorer&chrome=true&srcid=0B1iBWlUz8eUkYzk0YTY2MTMtZmMxOS00OWZjLWFjNjItYmJjYmExOGU2OGMw&hl=en_US
EXTRAS:
For beta 2 users: A moded main.jsp file is included. This will remove the drop down and replace it with additional links (share & add to playlist) on the top. It saves on space and looks alot better. Backup main.jsp, then you must rename main-beta2.jsp to main.jsp.
Tricky
trickydick
Postby muiz » Tue Aug 02, 2011 8:14 pm
please zip them and upload as 1 pack
muiz
Postby Hellscream » Tue Aug 02, 2011 8:17 pm
I will appreciate that to pls zip
Hellscream
google docs
Postby trickydick » Tue Aug 02, 2011 8:41 pm
it is ziped witht eh link above. once you open the link on the left pane, click File--> download orginial, or press CTRL+S. it will download the full zip file. Sorry its a google thing. can i change that?
Tricky
trickydick
Postby muiz » Tue Aug 02, 2011 8:49 pm
thx
(latest jwplayer = 5.7)
muiz
