Another frontend, need opinions (beta release)
Postby burjast » Sun Jul 18, 2010 11:37 am
still cannot play videos with rev5, music plays...
burjast
Postby brett » Sun Jul 18, 2010 12:13 pm
burjast wrote:still cannot play videos with rev5, music plays...
Can you give me some more info?
    -What codec is the video encoded in? (it's an avi correct?)
    -Does it play the audio for the video with just a black screen? (this happened to me while originally testing it)
    -Does the position/duration show the correct time of the video file?
    -Does the video start to buffer at all? (or even look like it it was trying to buffer)
    -The player 'bologna' has a check mark for the avi>flv transcoder in the Subsonic admin settings? I'm pretty sure I asked this before, but this was a huge oversight by me when I was originally testing it.
I'm not really sure what else to ask, I don't have linux installed at the moment. One last question, this might be stupid, but is FFMPEG installed? From what I gather it needs to be installed separate of subsonic.
brett
Postby jeremy » Sun Jul 18, 2010 1:34 pm
Fatal error: Call to undefined function mysql_connect() in /mnt/data/dynamic/supersonic/includes/connection.php on line 14
i cant get it working
always ending up with this error
in setup.php
jeremy
Postby oeh » Sun Jul 18, 2010 1:48 pm
jeremy wrote:Fatal error: Call to undefined function mysql_connect() in /mnt/data/dynamic/supersonic/includes/connection.php on line 14
in setup.php
Do you have mySQL insatlled?
Regards
OEH ;-}
oeh
Postby brett » Sun Jul 18, 2010 1:51 pm
in setup.php
That's a php error related to mysql not being compiled or added into whatever version of php you are running.
brett
Postby burjast » Sun Jul 18, 2010 4:01 pm
normal avi, tried many types...
in subsonic log:
[2010-07-18 18:05:31,630] INFO PlaylistInputStream - admin listening to "xxx.avi"
[2010-07-18 18:05:39,967] INFO PlaylistInputStream - admin listening to "xxx.avi"
[2010-07-18 18:05:42,001] INFO PlaylistInputStream - admin listening to "xxx.avi"
jwplayer:
Video not found or access denied: http://subsonic.server/blabla/....
cannot paste directly, but it's url to subsonic api, everything looks normal but don't know what to do :)
regards
burjast
Postby nncrypted » Sun Jul 18, 2010 11:16 pm
I'm running freenas 7.2 mysql and php are working fine can create the tables but can't connect to subsonic.
Getting this.
Connected to MySQL Server, users table exists.
Connection to Subsonic server failed. Local server ip/port:http://192.168.3.100:80/
MySQL server(local address):localhost
Subsonic server/port:http://192.168.3.100:8080/
It seems to be fine until it trys to connect to subsonic.
Any ideas?
nncrypted
Postby brett » Sun Jul 18, 2010 11:38 pm
nncrypted wrote:I'm running freenas 7.2 mysql and php are working fine can create the tables but can't connect to subsonic.
Getting this.
Any ideas?
What version of subsonic are you using?
The failed message only shows up if
http://192.168.3.100:8080/rest/ping.view?u=username&p=password&v=1.2.0&c=bologna
Doesn't produce a success message, Fill in the username and password with your login info for subsonic and go there in your browser, let me know what it gives you
brett
Postby nncrypted » Mon Jul 19, 2010 2:38 am
Using subsonic 3.9 as anything newer doesn't function properly on my freenas box.
This is what I get.
This XML file does not appear to have any style information associated with it. The document tree is shown below.
<subsonic-response xlmns="http://subsonic.org/restapi" status="failed" version="1.1.1">
<error code="30" message="Incompatible Subsonic REST protocol version. Server must upgrade."/>
</subsonic-response>
nncrypted
Postby brett » Mon Jul 19, 2010 2:45 am
nncrypted wrote:Using subsonic 3.9 as anything newer doesn't function properly on my freenas box.
This is what I get.
Ok, I thought that was why, what you can do is change your settings.php file to reflect v=1.1.1 after running setup part 1, or edit setup.php , look for this line
$data = "define('CREDS','u=$s_user&p=$s_pass&v=1.2.0&c=bologna');\n";
and change it to
$data = "define('CREDS','u=$s_user&p=$s_pass&v=1.1.1&c=bologna');\n";
Chat and deleting playlists from the interface will not work
brett
Postby nncrypted » Mon Jul 19, 2010 3:14 am
Cool thankyou.
Seems to be working.
So should I try and update to a newer version of Subsonic to get all the features functioning?
Thanx again sweet mod you have here.
nncrypted
Postby brett » Mon Jul 19, 2010 5:03 am
nncrypted wrote:Cool thankyou.
Chat and deleting a playlist is the only thing you'd be missing as of now, up to you
brett
Postby burjast » Mon Jul 19, 2010 8:41 am
what about "Video not found or access denied" error?
permissions seems to be right and subsonic starts to play, but jwplayer cannot open stream for videos, mp3's play fine
burjast
Postby jeremy » Mon Jul 19, 2010 12:13 pm
Getting this.
Connection to Subsonic server failed. Local server ip/port:http://192.168.3.100:80/ <- port 80 is default web gui freenas , maybe thats your problem
Any ideas?
i would give webserver port 4140
and subsonic 4040
maybe that works, and could you give me a how to get php5 working ?
running freenas shere but i cant get it working
package installing is ok
php5 and php-mysql installed
mysql installed and running
but php doesnt connect with mysql =(
Ps Brett keep up the good work (y)
jeremy
Postby nncrypted » Mon Jul 19, 2010 12:27 pm
I use 443 https for freenas gui, webserver on port 80, subsonic on 8080 it all works fine plus I'm running a nuke evolution test site and a vcd db movie database test site. All works fine. php and mysql on freenas is the worst install I've had to do to date but once it works its great.
Goto http://www.howtoforge.com/installing-my ... on-freenas and follow it to the letter. Then in my case I had to give more permissions to /mnt/dynamic/db/mysql then rehash. also the new phpmyadmin doesn't work with the new freenas find an older ver like 3.3.3 or older.
nncrypted
Users browsing this forum: Majestic-12 [Bot] and 12 guests
