Videoplayer Aspect Ratio Mod
Postby nRo » Mon Oct 17, 2011 3:29 pm
Hey guys,
I'm working on a small mod that allows to change the aspect ratio of the jwplayer, the player will keep the selected ratio when you enter fullscreen.
Update:
You can now switch between manual selection and autodetection whenever you want.
The flashplayer will be reloaded but it will keep the actual position.
Manual autoratio selection is disabled by default and autodetection is used.
Update2:
small bugfix: fixed icon toggle
Download:
Videoplayer AR MOD V2.rar
Installation:
copy the aspectratio folder to webapp/script and the videoplayer.jsp to /webapp/WEB-INF/jsp/
The changes in videoplayer.jsp are commented if you don't want to overwrite the whole file.
Just tell me if anything doesnt work.
nRo
Re: aspect ratio videoplayer
Postby cnliberal » Tue Dec 27, 2011 2:42 pm
I'd appreciate that. Ideally, auto detecting the aspect ratio would be the way to go, but I have no problem having a drop down. Thanks!
cnliberal
Postby nRo » Wed Dec 28, 2011 12:25 am
copy aspectratio.js to webapp/script and the videoplayer.jsp to /webapp/WEB-INF/jsp/
I will probably start working on this again if there is interest.
nRo
Re: Videoplayer Aspect Ratio Mod
Postby marzpete » Wed Feb 01, 2012 11:04 pm
works for me, thanks :o
autodetection would be great
marzpete
Postby nRo » Tue Feb 07, 2012 2:39 am
Update:
startpost updated with screenshots and downloadlink :)
Update2:
nRo
Postby siGh » Mon Mar 12, 2012 9:20 am
Installed it a while back. Excellent mod :)
siGh
Postby SparkyRih » Wed May 09, 2012 8:06 pm
Does this work on 4.6?
VMWare ESXi 5.5 > Ubuntu 16.04 > Subsonic 6.0 (Modded with PHP based registration feature)
SparkyRih
Postby SparkyRih » Thu May 10, 2012 7:01 am
cooking wrote:The changes in videoplayer.jsp are commented if you don't want to overwrite the whole file.
Just tell me if anything doesnt work. :oops:
Ok, I'll try it some time...
SparkyRih
Postby nRo » Thu May 10, 2012 9:08 am
SparkyRih wrote:Does this work on 4.6?
yes, it works on 4.6. You can just overwrite the videoplayer.asp if you don't have any other mods that use this file.
nRo
Postby SparkyRih » Thu May 10, 2012 9:23 am
Ok, thank you ;)
SparkyRih
Postby quatermass » Mon May 28, 2012 8:59 am
I just wish this mod was added to the Android client. :(
All my videos I display on my Android App just don't appear to use the screen to its best advantage on my HTC Desire HD.
Stuart Halliday
The Computer Man
quatermass
