Subsonic 3.7.beta1 released
Postby jigsaw » Tue Jun 02, 2009 9:43 pm
megariffer wrote:but i'm writing beacuse i just installed 3.7b1 and i found that i can't resize the frames anymore. is this gonna be fixed in the final version or i'm just dumb and missed something?
I'm not sure if this report got picked up? I have the same issue on IE8, Google Chrome and Firefox 3.5b4..
jigsaw
Postby sindre_mehus » Wed Jun 03, 2009 7:21 am
Sorry, that feature was sacrificied. You see, I changed the HTML to comply to the HTML 4.01 doctype. A side effect of this was that the frame borders got *really* ugly, so I decided to remove them.
I think the result is a lot cleaner visually, but I can understand that some will miss the option to resize it manually.
You can always change the frame proportions by modifying index.jsp, by the way.
Postby kdid » Thu Jun 04, 2009 4:05 pm
I also have noticed that the feature is gone. I will surely miss the possibility to resize the frames.
Have you a screenshot of how bad it looked with borders?
-- kdid
kdid
Postby jigsaw » Fri Jun 05, 2009 7:44 pm
sindre_mehus wrote:You can always change the frame proportions by modifying index.jsp, by the way.
Would it be possible to implement a configurable setting for the width of the left bar and the height of the bottom bar in the advanced settings tab? This could be seen as a work-around for the dropped feature.
jigsaw
Postby sindre_mehus » Fri Jun 05, 2009 9:03 pm
Hi.
To be honest, I'm not too keen on making it a configurable setting. Too many settings for everything make the application appear feature-bloated and more difficult to use. Secondly, it takes time to implement - time I'd rather spend on other features :wink:
I forgot to mention it, but the frame borders can of course be added again by modifying the index.jsp.
Postby mgrant » Fri Jun 05, 2009 10:00 pm
sindre_mehus wrote:Hi.
Can you explain a little more? I'd like to add the borders back.
thanks,
-mg
mgrant
Postby donpearson » Sat Jun 06, 2009 10:22 am
i think it looks a lot better without the borders, much cleaner.
Facebook Group:
donpearson
Postby jigsaw » Sun Jun 07, 2009 11:54 am
sindre_mehus wrote:Sorry, that feature was sacrificied. You see, I changed the HTML to comply to the HTML 4.01 doctype. A side effect of this was that the frame borders got *really* ugly, so I decided to remove them.
I couldn't quite see what the impact was of this change until I realized that you probably are using IE?
I tested re-implementing the borders in IE, and yes, they truly are ugly there. However, having borders in Mozilla Firefox, Google Chrome or even Opera doesn't actually make too much of a difference. There's a tiny black line in the frames, that's all. Not the big clumsy borderline as in IE. I agree that you shouldn't make everything customizable through settings, so I guess I'll have to live with changing this one after every upgrade myself :)
jigsaw
Postby twiztar » Mon Jun 08, 2009 7:51 pm
Dunno why, but I'm able to resize the frames by just dragging it where the border should've been.
twiztar
Postby geiman » Tue Jun 09, 2009 9:19 pm
Not sure if anyone else has had this problem; I've been searching for a few days with no luck. In 3.7 beta 1, subsonic crashes for seemingly no reason; I just noticed that a song I have that is only 128 kbps does not crash subsonic, however songs that are 192 kbps cause subsonic to crash. If I simply stream the music to my browsers flash player, it works great, but the jukebox feature for some reason wants to crash. My log file shows nothing unusual, the last messages are simply about playing the song; nothing abnormal. Anyone else have this problem? If its simply something with the beta thats fine, it just kills me that I can't fix the problem, or at least know what the cause is.
If you guys aren't sure I'll post this in the help section. The only reason I didn't post there first is because this is a beta, and problems should be expected.
EDIT: Found an error log file in my standalone directory; here is a portion of it:
# An unexpected error has been detected by Java Runtime Environment:
#  SIGSEGV (0xb) at pc=0x00007fe7b13a1610, pid=4619, tid=140633112115536
Signal Handlers:
SIGSEGV: [libjvm.so+0x5fcd20], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGBUS: [libjvm.so+0x5fcd20], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGFPE: [libjvm.so+0x4e0eb0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGPIPE: [libjvm.so+0x4e0eb0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGXFSZ: [libjvm.so+0x4e0eb0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGILL: [libjvm.so+0x4e0eb0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGUSR1: SIG_DFL, sa_mask[0]=0x00000000, sa_flags=0x00000000
SIGUSR2: [libjvm.so+0x4e35d0], sa_mask[0]=0x00000000, sa_flags=0x10000004
SIGHUP: [libjvm.so+0x4e3320], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGINT: SIG_IGN, sa_mask[0]=0x00000000, sa_flags=0x00000000
SIGTERM: [libjvm.so+0x4e3320], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGQUIT: [libjvm.so+0x4e3320], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
---------------  S Y S T E M  ---------------
OS:5.0
uname:Linux 2.6.28-11-generic #42-Ubuntu SMP Fri Apr 17 01:58:03 UTC 2009 x86_64
libc:glibc 2.9 NPTL 2.9
rlimit: STACK 8192k, CORE 0k, NPROC infinity, NOFILE 1024, AS infinity
load average:0.10 0.03 0.01
CPU:total 2 (2 cores per cpu, 1 threads per core) family 6 model 15 stepping 2, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3
Memory: 4k page, physical 2033744k(1490328k free), swap 5952040k(5952040k free)
vm_info: Java HotSpot(TM) 64-Bit Server VM (11.3-b02) for linux-amd64 JRE (1.6.0_13-b03), built on Mar  9 2009 11:08:22 by "java_re" with gcc 3.2.2 (SuSE Linux)
time: Tue Jun  9 09:27:41 2009
elapsed time: 3925 seconds
geiman
Postby donpearson » Mon Jun 15, 2009 4:26 pm
any idea when 3.7 will be ready sindre ?
Facebook Group:
donpearson
Postby sindre_mehus » Tue Jun 16, 2009 7:24 am
donpearson wrote:any idea when 3.7 will be ready sindre ?
One hour ago :D
Postby M0NG0 » Tue Jun 16, 2009 7:41 am
One hour ago :D
Sweet! Thanks Sindre! :D
M0NG0
Postby wally.nl » Tue Jun 16, 2009 8:06 pm
first 3.7 problem encountered with search see below. Everything else seems to be in working order.
Exception    org.springframework.beans.NotReadablePropertyException
Message    Invalid property 'query' of bean class [net.sourceforge.subsonic.command.SearchCommand]: Bean property 'query' is not readable or has an invalid getter method: Does the return type of the getter match the parameter type of the setter?
Java version    Sun Microsystems Inc. 1.6.0_07
Operating system    Linux 2.6.26-1-486
Server    Apache Tomcat/6.0.18
Memory    Used 76 of 125 MB
Stack trace    org.springframework.beans.NotReadablePropertyException: Invalid property 'query' of bean class [net.sourceforge.subsonic.command.SearchCommand]: Bean property 'query' is not readable or has an invalid getter method: Does the return type of the getter match the parameter type of the setter? at org.springframework.beans.BeanWrapperImpl.getPropertyValue(BeanWrapperImpl.java:544) at org.springframework.beans.BeanWrapperImpl.getPropertyValue(BeanWrapperImpl.java:536) at org.springframework.validation.AbstractPropertyBindingResult.getActualFieldValue(AbstractPropertyBindingResult.java:78) at org.springframework.validation.AbstractBindingResult.getFieldValue(AbstractBindingResult.java:337) at org.springframework.web.servlet.support.BindStatus.(BindStatus.java:118) at org.springframework.web.servlet.tags.form.AbstractDataBoundFormElementTag.getBindStatus(AbstractDataBoundFormElementTag.java:176) at org.springframework.web.servlet.tags.form.AbstractDataBoundFormElementTag.getPropertyPath(AbstractDataBoundFormElementTag.java:196) at org.springframework.web.servlet.tags.form.AbstractDataBoundFormElementTag.getName(AbstractDataBoundFormElementTag.java:147) at org.springframework.web.servlet.tags.form.AbstractDataBoundFormElementTag.autogenerateId(AbstractDataBoundFormElementTag.java:134) at org.springframework.web.servlet.tags.form.AbstractDataBoundFormElementTag.writeDefaultAttributes(AbstractDataBoundFormElementTag.java:123) at org.springframework.web.servlet.tags.form.AbstractHtmlElementTag.writeDefaultAttributes(AbstractHtmlElementTag.java:379) at org.springframework.web.servlet.tags.form.InputTag.writeTagContent(InputTag.java:139) at org.springframework.web.servlet.tags.form.AbstractFormTag.doStartTagInternal(AbstractFormTag.java:90) at org.springframework.web.servlet.tags.RequestContextAwareTag.doStartTag(RequestContextAwareTag.java:77) at org.apache.jsp.WEB_002dINF.jsp.search_jsp._jspx_meth_form_005finput_005f0(search_jsp.java:654) at org.apache.jsp.WEB_002dINF.jsp.search_jsp._jspService(search_jsp.java:188) at org.apache.jasper.runtime.HttpJspBase.service(HttpJspBase.java:70) at javax.servlet.http.HttpServlet.service(HttpServlet.java:717) at org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:374) at org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:342) at org.apache.jasper.servlet.JspServlet.service(JspServlet.java:267) at javax.servlet.http.HttpServlet.service(HttpServlet.java:717) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at org.apache.catalina.core.ApplicationDispatcher.invoke(ApplicationDispatcher.java:630) at org.apache.catalina.core.ApplicationDispatcher.processRequest(ApplicationDispatcher.java:436) at org.apache.catalina.core.ApplicationDispatcher.doForward(ApplicationDispatcher.java:374) at org.apache.catalina.core.ApplicationDispatcher.forward(ApplicationDispatcher.java:302) at org.springframework.web.servlet.view.InternalResourceView.renderMergedOutputModel(InternalResourceView.java:167) at org.springframework.web.servlet.view.AbstractView.render(AbstractView.java:239) at org.springframework.web.servlet.DispatcherServlet.render(DispatcherServlet.java:1158) at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:900) at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:808) at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:476) at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:441) at javax.servlet.http.HttpServlet.service(HttpServlet.java:637) at javax.servlet.http.HttpServlet.service(HttpServlet.java:717) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:265) at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107) at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:166) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.ui.rememberme.RememberMeProcessingFilter.doFilter(RememberMeProcessingFilter.java:142) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.wrapper.SecurityContextHolderAwareRequestFilter.doFilter(SecurityContextHolderAwareRequestFilter.java:81) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessingFilter.java:173) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.ui.AbstractProcessingFilter.doFilter(AbstractProcessingFilter.java:271) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.ui.logout.LogoutFilter.doFilter(LogoutFilter.java:110) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:249) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:149) at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at net.sourceforge.subsonic.filter.RequestEncodingFilter.doFilter(RequestEncodingFilter.java:43) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at net.sourceforge.subsonic.filter.ParameterDecodingFilter.doFilter(ParameterDecodingFilter.java:54) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at net.sourceforge.subsonic.filter.BootstrapVerificationFilter.doFilter(BootstrapVerificationFilter.java:54) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233) at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191) at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128) at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102) at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109) at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:286) at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:845) at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:583) at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:447) at java.lang.Thread.run(Unknown Source)
6,695 artists - 14,412 albums - 170,363 songs - 1462.83 GB - 12,978 hours
wally.nl
Postby sindre_mehus » Wed Jun 17, 2009 4:07 pm
Try reloading the top frame with the search field, or clear the browser cache if that doesn't work.
Return to Announcements
Users browsing this forum: Bing [Bot] and 3 guests
