External Hard Disk on Mac
Postby abeofarrell » Mon May 27, 2013 2:01 am
Good Morning folks,
Just wondering, is it possible to stream from an external hard disk connected to my Mac? If so, how do I enter the path?
Any help is very welcome.
Abe
abeofarrell
Re: External Hard Disk on Mac
Postby gurutech » Mon May 27, 2013 2:30 am
Is your Subsonic service running on the same Mac, or on a different computer on the same network?
gurutech
Postby abeofarrell » Fri May 31, 2013 2:06 am
Yes, My server is running on my iMac, and I have an external HDD connected to it so I want to make the media within the external HDD also available to stream.
abeofarrell
Postby gurutech » Fri May 31, 2013 2:28 am
You would need to find the path first. If I remember correctly, when you plug the drive in, it should pop an icon up on the desktop. Just click on that, then go to the Finder menu and go to "Get Info". (If you have 2 mouse buttons, you can right-click on the drive icon, then click "Get Info".
Under Get Info, you should see the mounting point of the drive (I can't recall what it would be, but it will show it.) Then just use that path to enter into Subsonic, followed by the folder the music is in.
For example, if the drive is mounted as "/media/external", then you would enter "/media/external/music/" under Settings/Media Folders in Subsonic.
gurutech
Postby abeofarrell » Fri May 31, 2013 8:50 am
Thank you, but it does not have path. These are the sections:
General (kind, created, modified, format, capacity, available, used, label)
more info (last opened)
name and extension
preview
sharing and permissions
Any other ideas?
abeofarrell
Postby hanker » Fri May 31, 2013 3:52 pm
abeofarrell wrote:
Any other ideas?
Try this:
Assume your hard disk is called
HD500
Then the path would be
/Volumes/HD500
If your hard disk has a space in its name, e.g., your hard disk is called
HD 500
then the path would be
/Volumes/HD\ 500
hanker
Postby sendreela » Thu Aug 15, 2013 12:47 pm
I am facing an issue with my led Tv is that when I connect my External Hard Drive, I am not able to see all the movies in it. Although all the old movies are still visible, but the new ones are not read. Can anyone please suggest a solution.
external hard disk
sendreela
