Subair Problems
Subair Problems
Postby davidthomp84 » Thu Apr 14, 2011 1:20 pm
Subair states that I am online however I cannot see any of my files, or mp3's
I have tried to change the player settings thru the web interface, as well as making sure my firewall is not blocking Subair
I am using windows 7 X64 with the most updated adobe air and I just installed Subair yesterday because I thought it would be a nice change to the web interface.
Any helpful tips will be appreciated
davidthomp84
Postby davidthomp84 » Fri Apr 15, 2011 12:37 pm
Ok fixed it... all I have to say is im dumb LOL
davidthomp84
Postby achoo5000 » Fri Apr 15, 2011 4:45 pm
It's bad manners to not say how you fixed it. Someone might come here with the same problem.
achoo5000
Postby nicknack » Sun Apr 17, 2011 2:24 am
achoo5000 wrote:It's bad manners to not say how you fixed it. Someone might come here with the same problem.
I thought the same thing as I am "that person". :(
nicknack
Postby davidthomp84 » Sun Apr 17, 2011 5:58 pm
Opps didnt even think to put that on here
When you use subair you have to use http://"IP address and port" not DNS name. Even if you donated and have a subsonic DNS you can't use that for subair. It must be the direct IP address and port.
When I did this is automatically worked.
Again sorry for not posting how I fixed it.
davidthomp84
Postby OlYeller21 » Mon Apr 18, 2011 2:46 am
This seems to be a common problem with Subair. We could probably sticky get it into the Wiki or sticky the question but does anyone know the username of the Subair developer? I know they've been on this forum in the past and may be able to make a change that stops this from being a problem with a small fix.
OlYeller21
Postby pha9992001 » Tue Apr 19, 2011 5:10 am
davidthomp84 wrote:Opps didnt even think to put that on here
http://[abc].subsonic.org should work in subAir, but when using this name, the port should be omitted as the redirect handles the port.
The whole server address thing needs to work a little better (auto detect whether or not user has added 'http://' to the address, etc). This will definitely be in the next release.
pha9992001
oh, you need http:// in front of the IP
Postby mvpittman » Sun May 08, 2011 11:43 am
wow, I'm *that guy* now. I didn't know subAir required "http://" in front of the IP address.
Although this post didn't specifically say that, it did lead me to that conclusion and fixed my problem. Thanks!
mvpittman
Postby jacob019 » Mon Jun 06, 2011 4:45 am
don't feel bad, I couldn't figure it out either until I read this thread
jacob019
Re: oh, you need http:// in front of the IP
Postby Kirk » Mon Jun 06, 2011 4:47 am
mvpittman wrote:wow, I'm *that guy* now. I didn't know subAir required "http://" in front of the IP address
Still? I thought they fixed that like five versions ago... seriously it would be so simple to use a little regex and add it if it's not there... :|
Kirk
Users browsing this forum: No registered users and 55 guests
