WAP interface
WAP interface
Postby scoochie » Fri Nov 09, 2007 4:35 am
I am having no luck with this whatsoever. I tried from my mobile device as well as from IE on a PC to know avail. on the PC i get HTTP ERROR: 404. on my phone i get forbidden access errors.
I have looked through all of the provided help; played with all of the applicable settings as i see them; and i have searched this forum but cannot resolve the issue of connection to the WAP interface.
I reallly like the program and would sincererly appreciate some input on this.
thanks
scoochie
Postby tberman333 » Tue Nov 20, 2007 4:02 am
What is the address you are using? It should be http://your_server/subsonic/wap
Can you connect to the standard interface on IE?
tberman333
Postby nowise » Mon Dec 24, 2007 5:33 am
I am also having this problem. I can access my server fine from my phone via the regular interface but when pointing to http://<my domain name>/subsonic/wap I get:
HTTP ERROR: 404
NOT_FOUND
RequestURI=/subsonic/wap
Powered by Jetty://
This happens even when I try to connect to the WAP interface locally on the server.
nowise
Postby lyrikles » Wed Feb 17, 2010 10:05 pm
I'm having this same issue, even when trying to access http://<SERVER>/subsonic/wap from Firefox and I've been unable to find any documentation on subsonic's wap. Any ideas? Thanks
lyrikles
Postby daveydz3 » Mon Feb 22, 2010 5:28 am
just put http://<server>/wap that worked for me
daveydz3
Re: WAP interface
Postby colin » Wed Mar 07, 2012 12:00 pm
This doesn't appear to work with iphone iOS5
When i navigate to http://mysite/wap i am able to successfully authenticate, but the page that loads is the .xml file that starts with this:
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE wml PUBLIC "-//WAPFORUM//DTD WML 1.1//EN" "http://www.wapforum.org/DTD/wml_1.1.xml">
This is what displays in the browser. Not able to test other devices.
colin
Re: WAP interface
Postby ytechie » Wed Mar 07, 2012 5:34 pm
Guys, the WAP is basically obsolete.I've never seen it work. Ever. The functionality it provides is minimal, and doesn't compare to the large amount of features found in the subsonic apps.
ytechie
