port forwarding solutions sharing
Re: port forwarding solutions sharing
Postby GJ51 » Wed Jun 20, 2012 10:31 pm
Then your port forwarding isn't set up properly.
If you use Skype, look at the entries for Skype in the router to see how it's setup and then use as a template for Subsonic.
You don't need to set up UPD ports for SS.
The most common mistake is not setting the incoming port to "Any".
Postby bushman4 » Thu Jun 21, 2012 12:02 pm
Looking at the picture you posted, can I guess that the "6000-6000" is source port and the "0-65535" is the destination port?
If so, you have it backwards... you want to open DESTINATION port 6000 from ALL source ports.
If not, post the top of the port mapping window so we can see the column headers from that table.
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby HighlandRanger » Thu Jun 21, 2012 1:30 pm
Here is my port forwarding... the highlighted section is for SS
My internal Static IP is 192.168.1.254
HighlandRanger
Postby bushman4 » Thu Jun 21, 2012 1:34 pm
Sorry, I was referring to the post by grant420 of a picture of his port forwarding.
Yours look fine. Sounds like your ISP is blocking one of them...
Glenn
Glenn Sullivan
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby HighlandRanger » Thu Jun 21, 2012 1:41 pm
Well I tried 8080,8081,6000, and several others... nothing seems to work. Why would the all of a sudden start blocking large chunks or all of my ports?
I've been trying to figure out what happened... I went on vacation for a week and when I came back I couldn't get SS to work outside the internal network. I also learned we had a thunderstorm while we were away. Could a power outage have somehow jacked up my router and that is what is causing the issue?
HighlandRanger
Postby grant420 » Thu Jun 21, 2012 2:06 pm
@Glenn: The screenshot is of my (working) Qwest modem's port-forwarding settings.
@HighlandRanger: What if you try adding a 0 in the left column (external port) for the two SS entries?
With the knowledge that you had a thunderstorm and lost power to the router, you might call the ISP and ask them for a replacement if nothing else works. Do you have screenshot(s) of your configuration from back when SS was working?
grant420
Postby HighlandRanger » Thu Jun 21, 2012 2:14 pm
When It was working before I just had SS handle the port forwarding... it was only after that I tried manual port forwarding since it wasn't working.
HighlandRanger
Postby HighlandRanger » Thu Jun 21, 2012 2:16 pm
Changing external to 0 did nothing.
HighlandRanger
Postby grant420 » Thu Jun 21, 2012 2:18 pm
HighlandRanger wrote:When It was working before I just had SS handle the port forwarding... it was only after that I tried manual port forwarding since it wasn't working.
This makes me think that you could try un-doing letting SS "handle" it, now that you have your router doing the port-forwarding... Have you tried changing the external port to 0 (zero) for the two SS lines?
grant420
Postby HighlandRanger » Thu Jun 21, 2012 2:21 pm
I am not letting SS handle port forwarding since I have added manual port forwarding. Changing externals to 0 does nothing.
HighlandRanger
Postby grant420 » Thu Jun 21, 2012 2:26 pm
HighlandRanger wrote:I am not letting SS handle port forwarding since I have added manual port forwarding. Changing externals to 0 does nothing.
I'd be willing to help you over the phone w/ this. Email me at grant 420 @ gmail dot com if you are interested.
We can use https://join.me to do a screen-sharing (i.e. web conference) session so that I can see what you're seeing...
grant420
Postby GJ51 » Thu Jun 21, 2012 2:30 pm
Have you tested the other ports going to 192.168.1.114 from canyoouseeme.org to verify that they are forwarding properly?
Postby GJ51 » Thu Jun 21, 2012 2:33 pm
Inside your network, what happens if you type http://192.168.1.254:8081 ?
Postby GJ51 » Thu Jun 21, 2012 2:34 pm
Have you disabled SSL and tested the http connection by itself?
Postby HighlandRanger » Thu Jun 21, 2012 2:42 pm
I can't see any port on my list from canyouseeme.org they ALL time out.
inside my network from another computer if I type http://192.168.1.254:8081 I get SS!
I have tried with and without SSL
I'm thinking something is wrong with the router. :(
HighlandRanger
Users browsing this forum: Google [Bot] and 21 guests
